Truly "universal" drive shafts
- Has thanked: 29 times
- Been thanked: 66 times
I found these at alibaba
I have something similar in my spare part collection, only that the dog bone part in screwed in directly ext to the joint. The other side ends in a metric axle.
I will post a pic later.
Wouldn't this pretty much solve all of the CVD / CVA problems with the WOIN builds with Klein / RPM wide arms?
I like my version better, but still a bit off the usual path.
*** POWDER - KING ***
- KidAgain
- Has thanked: 288 times
- Been thanked: 198 times
Re: Truly "universal" drive shafts
Adjustable bones nice option...................
Gone: RC10, Jrx-2 and Jrx-t
Current: 3 SC10 first gens, 3 SC10 Street Outlaw's, 12 RC10 DS’s, Carbon RC10T, RC10LSS,RC10L, RC10 Graphite,RC10 B44
These are mine, I actually have 2 pairs.
These will come in handy soon.
- Phin
- Has thanked: 61 times
- Been thanked: 182 times
Those are CRP driveshafts for the Scorpion. Would kind of be a waste to use them on a WOIN RC10.
Ok thanks for the info.
I always wondered what these are for. I got them YEARS ago with a lot off ebay.
I am planing on a custom build WOIN / Quadra ish.
I have no knowledge whatsoever on kyosho stuff.
Once I start that Project , I might try to use AE parts when things are sorted out.
- Lonestar
- Has thanked: 626 times
- Been thanked: 166 times
Nice findChewbacca wrote: ↑Mon Sep 16, 2019 11:35 am I found these at alibaba
Can you share the link pls? I'd like to check specs in detail (bearing size, dogbone pin size, etc...)....
Thanks!!!
Paul
I found them in THIS LINK
I believe your best bet is to use original shaft an the cut the ball and joint off and use this top part.
I am lucky enough to also have some kyosho style hex adapters, I have never used this kind, they are conical and lock by being wedged onto the shaft. I am wondering if they are going to be up to the higher torque of the modern brushless motors.
- Lonestar
thank you
- Garage Hack
- Has thanked: 136 times
- Been thanked: 5 times
Anyone use a AE part with the Klein arms? I just saw this thread while figuring out what cvd's (if any) will work to finish a conversion.
Has anyone on the forum here tried this or any other universal from AliExpress yet? It would definitely mean going metric on the rear hubs, unless you just use that top part.
Somehow I have the feeling it hasn't been done yet.
- Garage Hack
How about event a measurement of how long the axles should be?Garage Hack wrote: ↑Fri Dec 27, 2019 3:21 pm Anyone use a AE part with the Klein arms? I just saw this thread while figuring out what cvd's (if any) will work to finish a conversion.
- 2010 Views
- 20 Replies
- 2540 Views
Last post by scoobyrs25
- 907 Views
Last post by jkelm24
- 852 Views
Last post by dinglem
- 698 Views
Last post by Lowgear
- 134 Views
Last post by Dangeruss
- 1063 Views
Last post by victor_cathedral
- 1056 Views
Last post by isobarik
Users browsing this forum: Semrush [Bot] and 9 guests
