Lexan paint removal
Lexan paint removal
I'm sure I've read it somewhere, but I can't remember for the life of me what is safe to use on them without hazing the lexan.
I know Castrol Super Clean is a good product to use on plastics, I've used it to strip paint off many plastics (Tamiya hard bodies such as the Mountaineer lid/white parts, nylon RC10 parts, etc.) with great results, but never tried it on lexan.
Is that something that is safe on it or should I look for something else?
- mikedealer
- shodog
- Has thanked: 3 times
- Been thanked: 86 times
Re: Lexan paint removal
I found that Brake fluid will attack the plastic and leave it cloudybdrmbully wrote:brake fluid.
- mrlexan
- Been thanked: 10 times
And if you leave it in there too long, it will break down the lexan to the point where is has millions of small spider cracks and it literally falls apart.shodog wrote:I found that Brake fluid will attack the plastic and leave it cloudybdrmbully wrote:brake fluid.
www.gojammedia.com
www.gojammedia.com
i guess thats why my ultima body is so brittle,did the job though.guess it depends on the paint your also trying to strip.i tried nail polish remover without acetone, nitro fluid,brake fluid,depends if the paint is laquer or enamel.
2nd place is just the 1st loser
what is the suggested technique to use the nitro fuel to take off the paint. im thinking fill up a container and soak the body in there but they would use tons of fuel. would a rag dipped in it and laid in the body work? then put it all in a bag? i have no idea any tips? thanks!
peace, gamma
peace, gamma
- shodog
I just put a little bit of fuel in a bowl and use a paint brush dipped in it to gently scrub the paint off.
- 475 Views
Last post by shodog
- 26 Replies
- 3245 Views
Last post by flustorm99
- 45 Replies
- 9645 Views
- 2500 Views
Last post by muziyi
- 724 Views
Last post by mustang dave
- 1282 Views
Last post by marlo
- 1226 Views
Last post by THUNDERSTRIKE1
- 2097 Views
Last post by tizeye
Users browsing this forum: Google Feedfetcher and 11 guests
