anyone have defender? how about your feeling about that?
Do you have a defender?
- shodog
- Has thanked: 3 times
- Been thanked: 86 times
Re: Do you have a defender?
I’ve had my TRX-4 for a while now. The chassis has been solid. I haven’t broke anything yet. The servos and esc are junk. The servo for shifting between high and low stripped it’s gears. So did the replacement. Plastic steering horn splines stripped. After installing an aluminum servo horn then the servo gears stripped. The esc finally gave up the ghost after an intense day of rock crawling. Despite the lame radio gear I’d buy one again again. I think it’s a good value for what you get
- NomadRacer
- Has thanked: 83 times
- Been thanked: 77 times
Thanks for the insight shodog. I've been thinking about gettin one.
Bum on Direct Deposit
- shodog
The TRX4 is a great truck but there are a bunch of others just as good and better. My SCX10ii is way more nimble. The TRX4 is way better than the RC4WD Gelande
This was a recent rock crawl with my sons where the esc the TRX4 died. I plan to switch out the servos and esc/motor with some quality stuff and use a lighter weight body.
