1/10 Pan Car - MRC PRO-RACING (Inox A2 version)
- Has thanked: 263 times
- Been thanked: 155 times
Hi,
I started to restore oan MRC PRO RACING one year ago, i want to know if somebody try to put this body on that chassis.
https://www.ebay.com/itm/VINTAGE-58-VETTE-BODY-super-nitro-rs4-superten-tgr-tgx-fw03-fw04-pan-rc10-RC/153036721215?hash=item23a1b30c3f:g:aL0AAOxyzHxRJR1F:rk:18:pf:0
Jerome
Jerome
- Lonestar
- Has thanked: 626 times
- Been thanked: 166 times
Re: 1/10 Pan Car - MRC PRO-RACING (Inox A2 version)
Salut Jerome
the MRC Pro-Racing was pretty much only known in France, maybe a bit in western europe... you will have much more luck in getting info on VRC, frankly.
Reading about the body, it's a 225mm wide one, compared vs. the 235mm of the pan cars of the 90's and the AC Cobra body on the MRC pro-racing. In theory, the wheels would stick out a bit, but it might still be worth a shot!
A+
Paul
A+
Paul
Bonsoir Paul,
Thanks to reply!
I hoped to know about de roof height was the same the original AC Cobra boby.
I will go to find an original one.
Al screws will be change by some Inox A2 ones et i will give my touch to that restore and some polishing
This is the first step : Rear Axe et diff
To be continued ...
Jerome
Thanks to reply!
To be continued ...
Jerome
hi,
Next step : rear pod
To be continued ...
Jerome
To be continued ...
Jerome
Hi,
New step : rear pod + chassis plate
Original rims
To be continued ...
Jerome
Original rims
To be continued ...
Jerome
- NomadRacer
- Has thanked: 83 times
- Been thanked: 77 times
Thank you !
Next step : front end
to be contnued ...
Jerome
- Lonestar
love this car
Me too, it wasmy first pan car
Next step : the end is near ...
To be continued ...
Jerome
- works92
- Has thanked: 86 times
- Been thanked: 29 times
rear pod link device ( but "inline" ) , probably to be used on bumpy tracks...
curious to know how it handle .
beautiful build !!
and I'm not really in love with MRC cars, so it's a real compliment
beautiful build !!
- Has thanked: 2287 times
- Been thanked: 1994 times
That looks stunning , I'm not a pan car guy so again unusual for me to like one so much . One question about the rear pod , does it have a panard rod to stop left to right movement , I can't see one in the pictures so I was curious how it was located , the four links alone would allow left to right movement surely ?
- Lonestar
Absolutely love it!
I think it's the damper's spring that forces it straight...
must have been a nightmare to setup straight back then
- Has thanked: 13 times
- Been thanked: 78 times
The MRC car is more or less a copy of the PB Sizzler 1/10 car. The overall design is the same where the PB car uses the front end design and some parts from the Demon MF1 1/12 scale car https://classicrc.wordpress.com/1-12/demon-products/demon-mf-1/
Both cars are very rare today where the PB car was seen at Pro10 races in the UK and Germany, maybe others too. I think the MRC car was used more by hobby drivers, also it was cheaper than the PB car and maybe not really seen at races.
I still have two of the Sizzler cars waiting for restore but I can´t find the time ...
The PB Sizzler used a Panhard rod where there were two versions dependend on age of the car. It seems the MRC didn´t use a Panhard at least I can´t see one.
Another difference was the rear pod were the PB car used machined pod plates, the MRC car came with stamped aluminium plates what can be seen at the photos also.
HI All !!!
I took the time to assemble the new chassis tonight, it fits almost exactly in place of the original one, but there's really nothing to complain about.
When reassembling, I took the opportunity to put washers in some places to make it more consistent with the rest and I changed the screw on the shock absorber to make it look nicer.
I also installed aluminum front car mounts from an unknown Pan car chassis.
To be continued ...
Jerome
To be continued ...
Jerome
- 65 Replies
- 8819 Views
Last post by JK Racing
- 1682 Views
Last post by sandkil
- 656 Views
Last post by AscotConversion
- 715 Views
Last post by Trass
- 2687 Views
Last post by Trass
- 563 Views
Last post by clinehobbies
- 434 Views
Last post by adam lancia
- 1034 Views
