Academy SB Sport help
- RichieRich
- Has thanked: 34 times
- Been thanked: 19 times
Hey all, I know some of you have experience with the Academy SB Sport...Joey? Anyways, I took mine out this weekend for the first time in over a year. I ran a few packs then on the third it slowed down on the straights big time. I brought it in to check for a loose slipper, it was fine. Turns out the rear diff was barely holding together. I tightened it up and on the last turn, the diff screw snapped!!
I remember their being problems with these and until now, I've never had a problem. Is there anything more beefy I can use as a replacement? I'm sure Academy has something but that's going to require a trip to Ultimate Hobbies which is kinda far. Do any AE parts work?
- JK Racing
- Has thanked: 103 times
- Been thanked: 200 times
Re: Academy SB Sport help
I used the AE B4/T4/GT set up, the diff rings dont fit, but you can use the diff screw and nut, if I remeber right, you need to trim up the nut holder and it will be snug. I will search my old posts back on RC10B4 and see if I can find it.
Let me know if this helps.
- Erich Reichert
Ya a couple years ago when offroad nats was here in CT Greg tried to run that car with all the options in 4wd and the diffs kept giving up... the AE rebuild kit is key!
- RichieRich
Ok, looks like I need a diff rebuild kit with some extra washers to make up for the length of the stock t-nut, right?
- RichieRich
Alright, I figured it out. I need the 6573 thrust washer and 2330 T-nut. These should be available at Hobby People.
- 1289 Views
Last post by Mr. ED
- 1203 Views
Last post by FlyinGN
- 2950 Views
Last post by greazy
- 1475 Views
Last post by 59burst
- 149 Views
Last post by Dadio
- 78 Replies
- 11050 Views
Last post by 1911Colt
- 1255 Views
Last post by Jeff8877
- 65 Replies
- 8819 Views
Last post by JK Racing
Users browsing this forum: Tbot [Bot] and 7 guests
