Kyosho Ultima C2.1 Trailing Arm Conversion
- Has thanked: 822 times
- Been thanked: 2418 times
Something a little different for the Kyosho crowd. This conversion for the Ultima is similar to my other C2.1 conversions but lacks an upper deck and uses a Traxxas front bulkhead and special tower to simulate a Kyosho front end. It is wider than stock, pushing it to XL width up front with stock arms. Stock steering fits. You can use a Outlaw Ultima upper deck on this one if you choose, and you can use the Pro XL style uppers as well. Set up for RC10 battery boxes but if your using the Outlaw upper you can also use the stock zip tie setup. The chassis is set up for both stock trans and LW of course
Factory Works website
- NomadRacer
- Has thanked: 83 times
- Been thanked: 77 times
Re: Kyosho Ultima C2.1 Trailing Arm Conversion
Another version of the C2.1! Your teasing me man...making me have anxiety attacks for lack of one!
Bum on Direct Deposit
The ultima crowd is often left out, so I had to do something
- klavy69
- Moderator
- Has thanked: 561 times
- Been thanked: 265 times
Nice...the kyoxxas...traxxosho...kyoshoxas...traxyosho...kyoshox...ahhh, whatever its still nice
- Mr. ED
- Has thanked: 58 times
- Been thanked: 56 times
I think I even see Tamiya in the mix: the fronts wheels, not?
Yeah, I didn't want to spend a ton on wheels so I cut down a pair of $4 TRF wheels
Thats a sweet shape for the trailing arm set. Im a bit confused about the front end though. Is it the traxxas bulkhead that gives the kickup? So, it pretty much needs a top deck to brace the front end if its built to run?
- Incredible_Serious
- Has thanked: 1406 times
- Been thanked: 861 times
Todd,
I think 'Trasho' is the term you were looking for....
Seriously though, loving these C2.1 chassis kits.... great work yet again, GMV!
Yes it will be sold a couple different ways. It will fit a stock upper, it will fit pro xl mini braces, and I'll do a custom one like the 2.1 conversions where it will wrap around the battery. I just haven't had time to finish it offrccars4sal wrote: ↑Tue Jun 13, 2017 9:44 pm Thats a sweet shape for the trailing arm set. Im a bit confused about the front end though. Is it the traxxas bulkhead that gives the kickup? So, it pretty much needs a top deck to brace the front end if its built to run?
Ouch!I think 'Trasho' is the term you were looking for....
Certainly not a comment on your work, sir.... more a reference to the original buggies combined
Oh I know Alex, I think I have you pretty well figured out
Bollocks.
Finally getting back to the kyosho chassis- we are doing aluminum versions of the pro chassis now. Here is the first one on a rere ultima
- Mr. ED
Jeff, I really recommend at least a short brace from the bulkhead to the steering posts. Without that the nose bents and the gets torn around the front body mount.
- 958 Views
Last post by davidka
- 779 Views
Last post by bscotti
- 33 Replies
- 7099 Views
- 1067 Views
Last post by Asso_man!
- 1417 Views
Last post by prp
- 988 Views
Last post by LTO_Dave
- 1848 Views
Last post by Mr. ED
- 337 Views
Last post by 76jimmy
Users browsing this forum: Google [Bot] and 16 guests
