Original 6 Gear transmission to Stealth w/VTS slipper parts list
- Stuntmanmike1975
- Regular Member
I recently acquired a super clean Andy's conversion car with most of the available options from the time. It included the Graphite chassis, Andy's bulkheads, Andy's Shock Towers, Andy's trailing Arms, Front arms & Andy's body. It came with a "Pink" six gear transmission that I'm assuming was dyed or was it something else? (if anyone knows do tell)
My other question is:
In converting this to a modern brushless power plant with the stealth transmission exactly what parts will I need to use the b4-b6 VTS slipper etc??
I'm sure this has been go over many times here but I searched & searched these forums & couldn't find it, I'm sorry.
- Has thanked: 10 times
- Been thanked: 447 times
Re: Original 6 Gear transmission to Stealth w/VTS slipper parts list
You will need the entire stealth trans minus the slipper assembly and top shaft. Get a B4 topshaft and the v2 slipper plates spur gear and slipper discs.
If you have an original 6 gear motor plate, you will need to drill another hole to mount to the stealth.
- Stuntmanmike1975
- Regular Member
I'm doing the B4 Top Shaft upgrade to my Stealth Transmission and I thought I'd post the part numbers needed in case anyone else is wondering.
You will need:
ASC9601 - Top Shaft
ASC7486 - V2 Slipper Hubs (X2)
ASC9603 - Slipper Pads (X2)
ASC9651 - Spur Gear (81T)
ASC9739 - Slipper Spring
ASC7486 - Slipper Spring Washer
ASC6629 - 5-40 Diff Locknut
I managed to find all parts minus the top shaft on eBay taken from another car. I should get everything this weekend and I'll update how it goes. My trans slips a bit with 13T Brushless on a carpet track. I'm hoping this will do the trick.
You will need:
ASC9601 - Top Shaft
- 27 Replies
- 6882 Views
Last post by juicedcoupe
- 812 Views
- 23 Replies
- 2413 Views
Last post by JosephS
- 892 Views
Last post by sschering
- 1384 Views
Last post by Toasted Coastie
- 2886 Views
Last post by Seabass
- 1075 Views
Last post by orangemazda
- 3982 Views
Last post by Dirtcar75
