3D Printing
3D Printing
I know you can buy parts for these cars, however just curious if anyone has 3D printed an A Arm perhaps and how well did it hold up?
- Halgar
- Has thanked: 145 times
- Been thanked: 189 times
Re: 3D Printing
There is a company that is currently 3D printing/producing 1:1 cars. That would imply that the limitation of a consumer grade 3D printer would be the plastic that it utilizes, it may or may not be able to use stronger plastics, in which case, strength would be an issue.
Jay Leno uses a 3D printer to duplicate parts for many of his projects, some items are printed and used as is, sometimes the printed part is designed and fitted, then sent out to a casting or machine shop to duplicate. Regardless, 3D printing is being used in the real world, which means that if you can't use your consumer printer for making parts now, it won't be long before consumer level technology will be available to do so.
- Has thanked: 10 times
- Been thanked: 447 times
Re: 3D Printing
there are tons of parts made by members here and not on this forum on shapeways, or imaterialize. if you go to shapeways website and search on rc10, you will see a bunch of stuff.
most of the sintered nylon parts are somewhat tough, but not near the toughness of a molded part. In most cases, guys have drawn the arms to improve strength by adding extra material in the weak areas.
there have also been tests were people have attempted to improve the toughness by adding a filler material, the sintered parts end up having a porous structure so people have tried thin CA or urethanes with some success.
search shapeways on this forum as well to see a bunch of neat stuff guys have designed.
Re: 3D Printing
jwscab that shapeways website was exactly what I was wondering about. Thanks fellas!
- 1893 Views
Last post by j-sou
- 4101 Views
Last post by GreenHell
- 211 Views
Last post by silvertriple
- 1153 Views
Last post by LoCoCNC
- 3813 Views
Last post by Hcp22
- 790 Views
Last post by morrisey0
- 195 Replies
- 6354 Views
- 480 Replies
- 47191 Views
