Vintage Yokomo 834b
Vintage Yokomo 834b
After talking with my brother about our old RC cars and the fact that I have been working on an old RC10 that I purchased, he located an old Plano tackle box full of parts.
After opening this box I located some old Yokomo 834 parts. Anyways, I have got the bug to take the parts and build a complete car.
Can anyone here direct me to a good website where I could purchase some needed parts. I have been looking on Ebay, but there is not too much listed on that site. Thanks.....
Erik
White Hall, Md.
White Hall, Md.
- shodog
- Has thanked: 3 times
- Been thanked: 86 times
- DennisM
- Has thanked: 30 times
- Been thanked: 64 times
Re: Vintage Yokomo 834b
GomachV - Gospeed, can do the chassis.
http://www.rc10talk.com/viewforum.php?f=100
Gone fishing
- a01butal
- Has thanked: 33 times
- Been thanked: 39 times
Sometimes you can find stuff at Antonia'a store:
http://stores.ebay.com/Antonias-RC-Buggy-Parts-of-the-80th?_dmd=2&_nkw=4933
This is all very interesting!
Thanks for all the good info guys, I really appreciate it.
I'll post photos with updates when I get some new/used stuff in.
Erik
White Hall, Md.
White Hall, Md.
- Has thanked: 10 times
- Been thanked: 447 times
you have an ambitious project there, stick around ask questions, get into the B/S/T section and you will have some more openings to finding some of the harder to find pieces. Other than that, these guys have set you on the best path to finding parts.
check ebay early and often as well.
I would first start with a manual if you can track it down, I believe I have seen one on this forum, so you can match part numbers to missing parts. Of course, you can sub in stuff as well, like shocks and such.
Custom works dominator used some 834b parts so there is another avenue to explore.
Thanks for the info, I do check Ebay on a regular basis.jwscab wrote:you have an ambitious project there, stick around ask questions, get into the B/S/T section and you will have some more openings to finding some of the harder to find pieces. Other than that, these guys have set you on the best path to finding parts.
I did just pick up a brand new Hot Trick roll bar and I am waiting on an repo oem chassis.
Erik
White Hall, Md.
White Hall, Md.
Here is a little update on the 834b. I have this chassis on the way to Maryland, Thanks to GoMachV.
I'm am very impressed by the looks of this chassis.
Erik
White Hall, Md.
White Hall, Md.
Not much to update here. I have been cleaning parts from the front end of the 834b.
Any ideas on the best way to clean bearings? Just a good wipe down do or should I soak then in anything?
Here are some of the parts that I have acquired.....
Erik
White Hall, Md.
White Hall, Md.
one way can be a rpm bearing cleaner. holds it in a housing, spey a rc cleaner into the tip. like perfomrance plus. Then add some bearing oil and spin to lubricate. One i do it.
- Been thanked: 11 times
The gearbox and belt guide are amongst the rarest parts! You are pretty much there.
- 1663 Views
Last post by Lastenfield
- 1345 Views
Last post by Jerzi
- 2511 Views
Last post by Dadio
- 2211 Views
Last post by highwayracer
- 2140 Views
Last post by a01butal
- 1660 Views
Last post by GJW
- 3292 Views
Last post by coxbros1
- 23 Replies
- 3590 Views
Last post by Lonestar
Users browsing this forum: No registered users and 15 guests
