Kyosho Stinger MK1 Which grease goes where?
- Regular Member
This may be a goofy question but I haven't worked on any rc cars in 20 years. I am rebuilding a Kyosho Stinger MK1 and have no idea what kind of grease goes where. I looked at Tower and they have several different kinds. I would rather ask a goofy question rather than re rebuilding this car. Thanks for any help.
- Has thanked: 822 times
- Been thanked: 2418 times
Re: Kyosho Stinger MK1 Which grease goes where?
As long as your using bearings, the only place I would grease is inside the diffs. Any grease on the trans gears will get to the belt. The clutch bearing could use a little grease. Otherwise I would keep the car dry.
The manual does show grease points if you want to be accurate but I think they overdo it
As far as grease types, I like the associated black grease. Simple, cheap and available
Factory Works website
- Regular Member
Thanks for the help. Should the pins and the suspension arms be greased or just let dry?
Never imo! But I think the manual says to in some places
- 808 Views
Last post by airbats801
- 1690 Views
- 977 Views
Last post by Lowgear
- 25 Replies
- 4138 Views
Last post by gjeeper04
- 19 Replies
- 1904 Views
Last post by unixphreak
- 1019 Views
Last post by Squirrel40
- 1585 Views
Last post by USA-1
- 1950 Views
Users browsing this forum: Amazon [Bot] and 24 guests
