10-Four: The LEGEND Continues...
- LTO_Dave
- Has thanked: 46 times
- Been thanked: 225 times
Well, sort of.
I was going to make this an on-road build, and still might, but I'll figure something out once I have more parts.
Gomachv was kind enough to cut me some towers that resemble the old Factory Works pieces.
This build might make scr8p's builds look lightning fast, but it'll get done.
- Has thanked: 28 times
- Been thanked: 957 times
Re: 10-Four: The LEGEND Continues...
Hey my stuff gets done..... eventually. Especially if I have to use it. I'm sure I'll get at least one build next year to take to CT.
- mk-Zero
- Business Member
- Has thanked: 4 times
- Been thanked: 19 times
- Has thanked: 823 times
- Been thanked: 2419 times
A&L towers were thick, these are 1/8", and its exactly the same as theirs except the one screw hole so it should be finepumpkinfish wrote:Interesting towers. Will that rear tower have enough support?
Factory Works website
- mk-Zero
- Business Member
Yep, fingers crossed.
- LTO_Dave
Are they made from thicker material used for the normal towers? Or is it just the shape that might be the problem?mk-Zero wrote:Those thick towers are going to be CLOSE to the CVAs!
Hey, I have a dremel if need be.
The gap between the out drive and tower is very tight, but I doubt it will hit. If it does, a little shaving should be all that is needed
- 1364 Views
Last post by MOmo
- 992 Views
Last post by shodog
- 1861 Views
Last post by shodog
- 755 Views
Last post by dell
- 887 Views
Last post by shodog
- 2327 Views
Last post by slotcarrod
- 1027 Views
Last post by RichieRich
- 25 Replies
- 3280 Views
Last post by SFC K
Users browsing this forum: duckhead and 47 guests
