I have a number of products available for the RC10, that you can purchase from my Shapeways shop --> https://www.shapeways.com/shops/CPD
Available right now I have:
RC10 0-degree rear arm mounts (3 deg of antisquat) $10.40
http://shpws.me/JBbt
Used on sprint/oval cars where rear toe-in is not wanted
RC10 25-degree front caster blocks $10.50
http://shpws.me/JBbB
Replicas of the sought-after 25 degree blocks
RC10 10-degree kickup shims $6.00
http://shpws.me/JBbE
Used on flat chassis to give 10 degrees of kickup, such as sprint/oval cars
Stealth cap and spacer set $6.50
http://shpws.me/JBbK
Replacements for missing pieces from your Stealth case
RC10 25-degree front arm mounts $11.00
http://shpws.me/JBbL
These will give you 25 degrees of front kickup instead of the normal 30 degrees. Good for high traction surfaces
RC10 35-degree caster blocks $10.50
http://shpws.me/JBbP
These add 5-degrees to the caster caused by kickup. With the above 25 degree arm mounts they result in 30 degrees of caster
More products to come in the near future, including:
Ten4 4WD RC10 kit (which will be announced in a separate thread)
Stealth transmission case with 6-gear mounting pattern
bolt-in mid-motor stealth case
bolt-in mid motor bulkhead
bolt-in 4-gear mid motor stealth case,
and other innovative products to keep your RC10 builds interesting!
Thanks for looking!
-Brian
RC10 products by CPD
Moderator: mk-Zero
- 90 Replies
- 13290 Views
Last post by juicedcoupe
- 720 Views
Last post by sandkil
- 4213 Views
Last post by mk-Zero
- 2440 Views
Last post by Speed Chaser
- 31 Replies
- 2905 Views
Last post by hkp
- 952 Views
Last post by RC10th
- 385 Views
Last post by Caine
- 972 Views
Last post by railey72
