MRC Rabbit Dogbone hard to find!
- Regular Member
Hello everybody.
I have a little problem.
I'm wondering if you could help me to find a dog bone. I can't seem to find it. The RC Car is probably from mid 80's (MRC Rabbit).
Similaire to this:
I have lost one of them in a big field when the suspension decided to loosen.
Picture of the one I still have.
SPECS:
Total length: 63mm
Pin to pin length c/c: 57mm
Pin diameter: 3mm
Pin length: 8,7mm
Ball diameter: 7mm
(c/c = Center to Center)
Is this something that you have or know where I could find?
Or is there someone that could construct them for me in hardened steel?
I would like to have a couple of them.
Or do you have some other solution to my problem? I would like to be able to use my car again. It's lot of fun!
Regards
Andy - Sweden
Similaire to this:
SPECS:
Total length: 63mm
Pin diameter: 3mm
Pin length: 8,7mm
Ball diameter: 7mm
Regards
Andy - Sweden
- Been thanked: 288 times
Re: MRC Rabbit Dogbone hard to find!
That's very close to a Kyosho Optima dogbone, those are just a bit longer...62.5mm pin-to-pin. You could cut one and sleeve it, then JB Weld both cut ends into the sleeve...should work fine for a runner, and Optima dogbones are easy to find.
- DennisM
- Has thanked: 30 times
- Been thanked: 64 times
1/8 dogbone if I´m not mistaken.
This makes the optima dogbone uninteresting as replacement. If You give me a couple of days, I might be able to find something suitable in my mess
Gone fishing
True, if that's 1/8-scale, Optima 'bones wouldn't be strong enough...
- Regular Member
Thanks. I am checking with a couple of them right now to see if this would fit. I'll be back.
- Regular Member
Hi,
The MRC ref part is 16.211.
Try to find on ebay.fr May be.
Schumacher : Cat XLS, Procat, Bosscat, Cougar, Cougar 2000
Kyosho : Ultima 1, Triumph, Ultima II
Traxxas : TRX-1
MRC : MRX, Santana Junior, Santana 4x4, Santana Pro
Traxxas : TRX-1
- Regular Member
Traxxas : TRX-1
Traxxas : TRX-1
- 1669 Views
- 538 Views
Last post by y2kgtp
- 1418 Views
Last post by bozack
- 1563 Views
Last post by littleVETTE
- 720 Views
Last post by MelvinsArmy
- 540 Views
Last post by LoboNYC
- 116 Views
Last post by Kazoom
- 1023 Views
Last post by Toasted Coastie
