MRC Thunder King "Restomod"
- CruzinCustomz
- Been thanked: 10 times
Hey folks, just joined up after browsing through the forum and I really like what I see so I figured I'd throw some of my projects up. I like restoring/restomoding older rc's so I'll start with my current project. This is an MRC Thunder King I picked up on CL locally in full working condition. I ordered a set of bearings and started tearing it down for a refresh.
Original body next to the body I'm probably going to run it with, HPI 1979 Ford F150.
- CruzinCustomz
Re: MRC Thunder King "Restomod"
Converting front axles to accept hex style wheels vs the older bearing in wheel design.
17mm Adapters added all around, mounted up some old school meats
- Diamond Dave
- Has thanked: 567 times
- Been thanked: 103 times
- CruzinCustomz
Great job...everything fits nicely and the body is the cherry on top!
- CruzinCustomz
Thanks everyone! Took it for a test run yesterday with the Traxxas xl5 and single 550 motor I installed from a leftover project. Definitely feels a bit underpowered on the low end so I'll probably look into getting a different motor for it.
- CruzinCustomz
Haven't had time to do much else on it. I did get a chance to try on some different shoes
- Lonestar
- Has thanked: 626 times
- Been thanked: 166 times
Cool stuff Interesting that you flio rear hubs to use as front hubs, yokomo yz10-style You end up with trailing vs in-line axle, but who cares!
Keep it up
Paul
Keep it up
Paul
- Regular Member
Hey,
I was wondering if you had a parts list for the carriers and gear you used to allow for hex wheels? I just received a Thunder King for rebuild and am trying to figure out my options. Any luck finding dog bones or some substitute? Thanks!
- 3182 Views
Last post by civilguy
- 537 Views
Last post by purpletimbo
- 2643 Views
Last post by mikmuel
- 67 Views
Last post by Lowgear
- 109 Views
Last post by Dangeruss
- 2078 Views
Last post by vwjuice
- 1069 Views
Last post by Beatnik
- 117 Views
Last post by Kazoom
