RC10 Dual Sport Mid-motor Conversion
I would like to convert my RC10 Dual Sport to a mid-motor set-up. However I am at a loss as to how to properly undertake this task. First, where do I drill the holes if I am using a stealth transmission? If I leave the transmission in it's existing location and simply switch it around, my new holes will be right on top of the old holes. Do I need to shift the transmission forward a bit? Second, I have read on this forum that I will need to add a gear. How do I do this?
- Has thanked: 750 times
- Been thanked: 26 times
Re: RC10 Dual Sport Mid-motor Conversion
Hi,
It is a lot of work, if you are using a stock aluminum tub it will end up looking like Swiss cheese,
Lot's of holes
If I was to do it again I would start with a graphite chassis without the bulkhead holes and gearbox
holes drilled.
At the top of the page is a search function, try typing in mid mount, there should be some
information available to help you.
Cheers, Dave.
Lot's of holes
holes drilled.
Cheers, Dave.
- Has thanked: 822 times
- Been thanked: 2418 times
No need to add a gear, just flip the motor plate and topshaft to the other side, then cut off the part of the motor plate that overhangs.
As far as holes go, grab a piece of thin cardboard. Lay it under your chassis and make marks for the suspension mounts, bulkhead, and trans. Ignore the 6 gear holes. Then, flip it around and center it on the suspension mount holes. Centerpunch the stealth holes and bulkhead holes thru the cardboard onto the chassis. Then just drill.
Then you will want to brace things up. Leaves the chassis pretty weak.
There are a lot of threads on this so have a look around.
Factory Works website
What are the "6 gear holes"? I saw reference to this before and that's primarily what threw me off.
I have identified the four(4) suspension mount holes, the two(2) bulkhead mont holes and the four(4) small stealth transmission holes. I assume that the additional four(4) holes are what you are referring to as "6 gear holes".
Yes, those were for the old trans. Ignore them
Gotcha! I just pulled out an old transmission and now I see exactly what you are referring to!
THANKS!!!
THANKS!!!
- Phin
- Has thanked: 61 times
- Been thanked: 182 times
Easier to convert a Nitro DS to a mid motor electric....all you'd need is one of these: http://www.ebay.com/itm/Associated-GT-Electric-Motor-Plate-Vintage-Trick-Conversion-Rc10-Losi-/121552987033?pt=Radio_Control_Parts_Accessories&hash=item1c4d1f6399
Wouldn't have to swiss cheese and hack up a tub that way either.
I'm in agreement there, unless the tub is already damaged it's such a waste of a good chassis
I have a brand new RC10 Dual Sport milled chassis but I think that I will just eBay it rather than "swiss cheese" it!
Since I will need a chassis that approximately 40mm longer than stock, I will most likely make my own out of aluminum.
I just wanted to make sure everything was going to fit properly on the stock chassis before I tackled fabricating my own chassis out of aluminum.
Sweet, that's good to hear!
Hi Guys,
When I did mine I didn't touch the rear suspension mounts, I used another chassis and put the
two chassis's top to tail, using screws through both suspension mount holes, re-drilled the gearbox
and bulkhead holes.
I hope that makes sense
It would be much better to start with a blank chassis plate.
You do need to use a shorty LiPo or solder up your own Sub C's in a 4 + 2 pack using the stock
length chassis.
What Phinn said, a DS or GT nitro electric conversion also sounds promising.
Dave.
and bulkhead holes.
length chassis.
Dave.
It makes sense. I think I will have enough room for the LiPo since I am extending the chassis in length by 45mm.
or wait till the guys making a mid motor rc 3d parts are released. for off road. same trans, same bulkhead and go from there.
Do it! I have an old gold pan that I lowered back in the day that we used to road race. But, I can't bring myself to mid-motorize so I'm building a spare/used parts Old is New mid motor car that will remain an off road buggy. I'd love to do a Mid Motor DS if I can find one reasonably priced. lol
-Mike
RC10T | Kyosho Lazer ZX - 55mph | Mid Motor RC10 Pan Car Conversion - 72mph | OIN RC10 spare/used parts build - 69mph | 4x4 MonsterT build
86 ascMcLaren Capri 5.0 | 86 Mustang SVO
mikemartinelli.com
My Shapeways Stuff
mikemartinelli.com
My Shapeways Stuff
- 1027 Views
Last post by markt311
- 1127 Views
Last post by THUNDERSTRIKE1
- 31 Replies
- 7714 Views
Last post by LoboNYC
- 106 Replies
- 9243 Views
Last post by DaveM
- 1359 Views
Last post by D Nozzle
- 1055 Views
Last post by Chewbacca
- 40 Replies
- 5288 Views
Last post by Asso_man!
- 810 Views
Last post by DJ_rc10
