Tamiya Tyrrell P34 "1977"
- THE H.P FREAK
HI!... O.k I picked up this original Tamiya Tyrrell P34 from Andyaus a little bit ago. Was in decent but rough shape. As soon as it came I started working on it. I always wanted one of these. :woohoo: I saved both mirrors and the two aluminum mounting brackets off the original body. The rest of it went into the garbage. Too far gone to be salvaged. My re-re Tamiya Tyrrell P34 needed a driver's side mirror anyway so now it has one. I tore the car down and let all the parts soak in a plastic tub of Greased Lightning over night. Next day started cleaning 38 years of dirt and grime off of it. The parts came pretty clean but now you can tell this car was run a bit. Scratches all on the bottom of the chassis plates. No big deal. I decided then that all the aluminum parts would be fine glass beaded and sent out to be powder coated. Nice thing about my glass beader is that it takes small scratches out quite easily. After powder coating you will never tell they were there. I'm going to go with a aluminum powder coating colour so it will be hard to tell the difference. The main chassis plate was pretty bent and the stiffening grooves were disfigured. I used to be a Way cover repairman in a fabrication shop so this was easy to fix. Took about a hour but got the chassis plate almost good as new. I ordered a NIP body for the car and it came in today. I also cleaned up the upgraded 540 motor. I ordered a NIP steering set that should arrive next week. Here's some pics of the process so far.
Car when I bought it : (Andy's pics)
- THE H.P FREAK
- THE H.P FREAK
Re: Tamiya Tyrell P34 "1977"
HI!... So NIP body came in today :
All the chassis parts degreased and cleaned :
All the chassis parts glass beaded :
- THE H.P FREAK
HI!... They are currently in vacuum sealed bags. Going to get them powder coated later this week.
- SMOKE-DOG
Nice! Will be following this resto. Always had a thing for the real P34 six wheeler. I have the re-release F103 version with some mods.
TC showroom: http://tamiyaclub.com/showroom.asp?id=18447
- THE H.P FREAK
HI!... Thanks, I also have a re-re version as well.
- THE H.P FREAK
Re: Tamiya Tyrrell P34 "1977"
HI!... Just an update. The NIP steering set came in today. Also ordered a can of Tamiya TS-15 and TS-26 for the body. Should be here next week. I dropped the glass beaded parts off at the powder coaters tonight. Going with a light silver metallic. Cost? $15. lol! Hopefully I can start assembling this thing soon.
- THE H.P FREAK
HI!... Well the paint showed up today. Might paint the body tomorrow depending on how I feel. Also the NIP P34 steering set showed up.
- THE H.P FREAK
HI!... Well I picked up the powder coated parts today. They look good. Hopefully I can start assembling it soon. What I still need to find is the rubber tires that came on the TYRRELL P34. I know the re-re had the same tires. But I can't seem to find any. People would have to replace the ones on the re-re eventually, so where do you get them from? Anyone?
- THE H.P FREAK
HI!... Wheels came in today. Just going with the huge rear foams until I can find a set of the original rear rubber ones.
- bearrickster
- Been thanked: 5 times
- 41 Replies
- 770 Views
Last post by GreenBar0n
- 1097 Views
Last post by SFC K
- 597 Views
Last post by proffesso
- 520 Views
Last post by SMOKE-DOG
- 614 Views
Last post by tiger1
- 2704 Views
- 1189 Views
- 451 Views
Last post by mark
