Spray paint choices
- DMAT
Spray paint choices
To sum up the post below. I used a duratrax rattle can to paint with and it was horrible. Tamiya color cans are gone at my LHS. What can I use in place since i dont want to make the jump to an airbrush system yet.
So with tamiya color paint no longer being sold at my LHS, I decided to try out one of those duratrax can. I gotta say im sorely disappointed in it. being used to the tamiya color now, I knew what to expect and painting when pretty easily with the first 2 colors (black then Silver). When I got to to putting on the 3rd color (Red), I its just hard to put into words. The volume from the can was way too much, I tried to move the can faster but then it wasnt painting enough and you could see through parts of the paint job. I go for another quick pass and all of a sudden its now starting to show through the other layers of paint I did. Since I was doing the wing in this color too. The effects of its spraying were pretty bad. Its appearance is really gritty (yes I shook the hell out of the can before using) after the first pass, I could still see light passing through all over. So I did another one and it just caused lots of run and there is still light coming through. Worse of all, the color barely matches the can, Its a red all right but a good bit darker than it should be compared to the can.
I'm trying to get better at this painting bit but I can work with these. Yes i could switch over to an airbrush but im not ready to bit the bullet to get a decent setup.
Re: Spray paint choices
That sucks I picked up a can of that the other day, haven't had a chance to use it yet but now not really looking forward to it!
- Has thanked: 822 times
- Been thanked: 2418 times
Sounds like it was a translucent paint, like the Pactra candy colors and such. They are put down and then backed with an opaque color- silver, white, etc. What is the name of the red you used?
Factory Works website
Pactra is sadly gone now
- DMAT
tamiya color PS-5 (black)
tamiya color PS-12 (silver)
Duratrax Metalic Red. DTXR4264 / PC264
maybe this one is suppose to be backed with something still doesnt get around the issue of how it sprayed out.
So you used Duratrax over Tamiya? I would not expect that to go well to be honest.
After a little digging, the Duratrax basically IS the old Pactra, Duratrash partnered with testors to bring it to production. That means it is a laquer for one, so stay away from acrylics with it. My experience with Pactra metallic and pearl colors is that they are just a tint and need a backing. Also the metallic will have a rough feel because of the metal flakes in it.
- THEYTOOKMYTHUMB
- Has thanked: 2122 times
- Been thanked: 1346 times
Well that blows. I haven't bought any paint in a good while so I didn't even realize it. When did that happen? Apparently I've been asleep...gomachv wrote:Pactra is sadly gone now
Testors discontinued it early this year or so, but the duratrax picks up where they left off apparently- some colors are even named the same lol
- THEYTOOKMYTHUMB
Good to know. I find Tamiya to be a bit smoother anyway.gomachv wrote:Testors discontinued it early this year or so, but the duratrax picks up where they left off apparently- some colors are even named the same lol
Thats interesting. I actually just bought some pactra from philshobbyshop.com. they have a good selection left if really want them.
- TRX-1-3
- Has thanked: 1399 times
- Been thanked: 764 times
Just bought some "Spaz Stix" paints. FL Yellow, FL Blue, and White. We'll see. I have only used the Tamiya and Pactra paints in the past. With the RTR and pre-"painted" bodies, who in the hell needs a quality paint anymore? Right? Wuuf. I'll report back.
Mark
Mark
- 36 Replies
- 689 Views
Last post by GreenBar0n
- 895 Views
Last post by uniquenamehere
- 180 Views
Last post by morrisey0
- 1007 Views
Last post by Meakz1973
- 20 Replies
- 1953 Views
Last post by Asso_man!
- 924 Views
Last post by blubblood
- 1229 Views
Last post by lmw94002
- 471 Views
Last post by juicedcoupe
