Pitch/module of 1:8 Delta/Associated clutch/drive gears?
I have a Delta CK790E, basically it's the late 70's/early 80's CK780 pancar converted to E-drive.
I'm missing all kinds of parts for it, mainly original electric components.
I did find a period correct Astro 015 motor. Now I need a suitable pinion for it, the motor has a 4mm output shaft but I don't know where to look because I'm not sure what the pitch of the spurgear is...I do know that the pitch is the same for all Delta and Associated vintage gascars.
Can you help me?
Can you help me?
- a01butal
- Has thanked: 33 times
- Been thanked: 39 times
Re: Pitch/module of 1:8 Delta/Associated clutch/drive gears?
The assembly instructions call for part number GR-11E but that doesn't give us any hint what the pitch is. The early 1/12 scale cars had 32 pitch pinion gear and that part number was GR32-11A so must have been some difference. I know another member here you have dealt with from Germany knows about the 790E and maybe he can help.
Do you have the instruction manual and blueprints for the 790E? If not I can email them to you.
This is all very interesting!
Thanks Al! I sent you a PM.
I have a few original Delta GR-32-11A pinions, and the pitch on those does not match (too fine) the Delta spurgear of my 790E (same as spurgears for all non-diff Delta CK pancars)
I do know that I would need either a 9/10 or 11 tooth pinion....with a 4mm hole...but which pitch size?
Thanks again!
Thanks again!
- a01butal
Mick, I sent you a pm.
- Phin
- Has thanked: 61 times
- Been thanked: 182 times
If you've got a spur handy to measure, you can figure out the pitch, or module, by dividing the outside diameter by the number of teeth plus 2.
Thanks Al! How are you?
Yes, for some reason my PM was not sent....can't find it in my 'sent items' folder either...I clicked on 'post reply', is that correct?
Anyway, thanks for your help. Yes, I did receive the 790E instructions you so kindly sent to me through Aaron, thanks again!
Could it be that these gears have a metric size, where the term 'module' is used to identify pitch etc?
Anyway, I'll also send Gunther a message as you suggested.
Kind regards, Mick
Kind regards, Mick
Thanks Phin, I'll try that...the module may be metric on these...Phin wrote:If you've got a spur handy to measure, you can figure out the pitch, or module, by dividing the outside diameter by the number of teeth plus 2.
Thanks!
The diameter of my Delta GR-A spurgear is about 53mm measured at halfheight of the teeth.
It has 50 teeth, so 53/50=1.06 plus 2 equals 3.06
I am inclined to call this a module 3 gear. That makes sense, the teeth are spaced 3mm apart.
So I guess I need an 11 tooth module3 piniongear...with a 4mm hole for the motorshaft.
- Phin
Sorry it's od/(number of teeth+2)
And it's the full outside diameter of the gear...from the top of the tooth.
Ok, I just ordered a Losi LOSA3571 mod1 11 tooth pinion...I hope it fits!
Thanks for the help and suggestions guys!
Mick
Mick
Received the Losi module1 11tooth pinion.
My motor shaft is 4mm, and the hole in the pinion is 5mm so I used my lathe to fabricate a small adapter (more like a bushing) and now it fits!
- Has thanked: 135 times
- Been thanked: 23 times
aip47-2008 wrote:Nice work there Mick!
Thanks Aaron!!
- 1206 Views
Last post by LemonC
- 900 Views
Last post by asashaw
- 161 Views
Last post by OldSchoolGuy
- 3000 Views
Last post by Taylorm
- 1323 Views
Last post by polarbear
- 771 Views
Last post by Brat
- 3982 Views
Last post by Dirtcar75
- 1402 Views
Last post by badhoopty
