Ayk viper shock absorber size
- Been thanked: 11 times
Hi experts
Looking for the approximate shock lengths( front and rear) for the viper.
I am looking for alternative shocks so this information would be useful!
Thanks in advance
Thanks in advance
- Been thanked: 288 times
Re: Ayk viper shock absorber size
I guess it would be helpful to know the stock shocks' uncompressed length. 3Racing makes excellent dampers in a wide variety of sizes, and if you can find something close to your uncompressed length, you can adjust things 5 to 10 mm or so either way by changing the ball-ends or putting plastic spacers under the piston rings.
- Has thanked: 822 times
- Been thanked: 2418 times
That's what he is after- he doesn't have the stock ones to measure. Surely someone does around here...Coelacanth wrote:I guess it would be helpful to know the stock shocks' uncompressed length
Wish I could help naus, but I have no viper
Factory Works website
I think if the car was built with only the shocks missing, you could get a pretty good idea for a shock's uncompressed length just by adjusting everything (camber, desired resting ride height) and measuring. Just get a ruler or calipers and measure between the centers of the mounting point holes...if nobody has these shocks, that's the method I would go by. That's pretty much how I got the suspension dialed in for CYANide and the front end of the Barney Optima.
Did you get that one off ebay that was missing shocks? I watched it for a while,, but couldnt allow myself to spend that much.
- DennisM
- Has thanked: 30 times
- Been thanked: 64 times
If You´re a TC member, search for the Viper and give one of those guys a shout - I bet You they´ll lend a hand.naushad wrote:Hi experts
Thanks in advance
I´ve only got The Trail Buggy and a Buffalo/Bobcat
Gone fishing
I dont use TC much...hoping to get the info here as some have restored vipers.
You lazy lot...
You lazy lot...
I think it might be a problem installing 3rd-party shocks on a Viper, due to those weird, extended skinny end-tubes that AYK designed their shocks with. Unless you could fit a long enough ball-end instead...
I wonder if something like a 1.32 shaft and .71 body would get the length and throw then run a wheel collar to hold the cup on the shaft
- 24 Replies
- 2756 Views
- 27 Replies
- 4946 Views
Last post by Pheonix
- 1308 Views
Last post by saga101
- 1633 Views
Last post by Asso_man!
- 2936 Views
Last post by Wahrsuul
- 1151 Views
Last post by besty22
- 1816 Views
Last post by Bormac
- 1271 Views
Last post by Ayk Viper
