What type of plastic was the Marui Galaxy Chassis?
- urban hype
Does any on know if the Marui Galaxy chassis was made from ABS or was it a different plastic?
Giving old thing a new life!
Check out my latest project:
The Danny Thompson Nitro Panda from Thunder Tiger
http://www.rc10talk.com/viewtopic.php?f=33&t=33149
- Lonestar
- Has thanked: 626 times
- Been thanked: 166 times
Re: What type of plastic was the Marui Galaxy Chassis?
melt more ABS with acetone and use this to "solder" the broken bits. Then sand. It's darn solid then.
- Been thanked: 288 times
That's actually a great idea! I remember seeing a recipe to make your own home-made acrylic cement by melting chunks of acrylic in acetone...that's the same kind of idea.Lonestar wrote:melt more ABS with acetone and use this to "solder" the broken bits. Then sand. It's darn solid then.
Kind of on topic, be sure not to put acetone anywhere near your Hunter/Galaxy wheels, they'll melt. (I had some drab old silver paint on the Galaxy I restored for my brother, and used a dab of acetone to remove the paint. Well, the paint came off real easy...and then some of the wheel surface, too.)
- urban hype
Thanks for the info guys. Since the chassis is ABS I am going to do a solvent bond. I will most likely use something like tenax 7R or ambroid proweld. Both of them are MEK based as I understand. These are straight up cracks so no filling is required.
- 237 Views
Last post by RCGaz
- 2851 Views
Last post by R Cane
- 65 Replies
- 12890 Views
- 268 Replies
- 16512 Views
Last post by silvertriple
- 47 Replies
- 5993 Views
Last post by Frankentruck
- 968 Views
Last post by crusaderlyf
- 952 Views
Last post by twiningmike
- 1278 Views
Last post by RC10th
