rc10 mid motor
rc10 mid motor
I saw a chassis on ebay a while back with these strips cut out and thought it looked pretty cool. Form over function as I knew the chassis would be far less rigid. I took a beat chassis and started to work on a prototype mid motor. Oh well, here goes...
- Attachments
- rc 003.jpg (148.53 KiB) Viewed 2335 times
- rc 002.jpg (142.48 KiB) Viewed 2332 times
- rc 001.jpg (114.16 KiB) Viewed 1811 times
- Mr. ED
- Has thanked: 58 times
- Been thanked: 56 times
Re: rc10 mid motor
you need to lower the inner mounting point for the rear turnbuckles, and a 'mad max' style body.
- bgruen
Re: rc10 mid motor
You also need to flip the spur gear to the other side, or your buggy will go backwards when you pull the trigger.
Bob
Bob
Writer, producer, and director of The Hobby Stop:
Available on:
Available on:
- Amazon
- iTunes
- Google Play
- YouTube Movies
- Microsoft Store / X-Box
Re: rc10 mid motor
Mr. Ed,Mr. ED wrote:you need to lower the inner mounting point for the rear turnbuckles, and a 'mad max' style body.
Why lower the rear turnbuckle mount (shock travel is only about 1/4")? Thanks!
- Mr. ED
Re: rc10 mid motor
Because your rear wheel will lean outwards when the suspension is compressed.
This will give you very little grip in the rear during cornering.
Terry SC was friendly enough to point out a similar problem with the front links on one of my own projects.
Re: rc10 mid motor
Thanks Mr. Ed... I'll work it out on the next build.Mr. ED wrote:Because your rear wheel will lean outwards when the suspension is compressed.
- 1286 Views
Last post by integra22t
- 1862 Views
Last post by mikea96
- 40 Replies
- 4695 Views
Last post by BloodClod
- 34 Replies
- 4070 Views
Last post by Lonestar
- 27 Replies
- 3594 Views
Last post by GoldRush
- 505 Views
Last post by Frankentruck
- 33 Replies
- 4099 Views
Last post by lowrydesign
- 106 Replies
- 9240 Views
Last post by DaveM
Users browsing this forum: No registered users and 31 guests
