lunsford ti-turnbuckles
picked up a set that says for T2/GT/T3. It is the punished series. When I compare the length they are shorter then my current ones. I was under the impression that the gt and T2 are the same lenght as the 10T..
- Has thanked: 822 times
- Been thanked: 2418 times
Re: lunsford ti-turnbuckles
The T2,GT and original 10T are all the same length
Factory Works website
- Has thanked: 28 times
- Been thanked: 957 times
Must have needed some coffee. Ater I got in the workshop and locked my kids out I reread what I posted. Hear it is again....the new set has two diff length. 4 rods are 2-5/8 and two are 2-3/4.
The technacraft I pulled out my box are SHORTER then the all four 2-5/8 by 1/8. Not really much but a 1/4 shorter then the longer two. I'm. Thinking the longer two are good for the rear and the four shorter are good for the front.I thought all six would be the same size..
- LoboNYC
- Has thanked: 814 times
- Been thanked: 344 times
Somewhere along the line Lundsford must have switched things up cause bitd the bags had all 6 the same length
Seems similar to the Assoc T4 turnbuckles. I just placed the two shorter on my steering (AE version not lundsford). I believe I looked in the T4 manual if I remember correctly to see where the shorter ones went.
- teman
- Been thanked: 6 times
Not sure why, but the steering pairs were made longer than the others. All of mine are that way.slvrback wrote:....the new set has two diff length. 4 rods are 2-5/8 and two are 2-3/4.
I'm speculating here, but maybe a change was made after Asso changed to the larger/longer ball cups? In any event, I'm pretty sure you can buy the shorter pair by itself if need be.
-Kevin
- 436 Views
- 1404 Views
- 25 Replies
- 2086 Views
Last post by kaiser
- 645 Views
Last post by frgna
- 627 Views
Last post by justinspeed79
- 25 Replies
- 1783 Views
Last post by RichieRich
- 477 Views
- 20 Replies
- 2000 Views
Last post by TRX-1-3
Users browsing this forum: Ahrefs [Bot], Amazon [Bot], DotNetDotCom.org [Bot], Google Adsense [Bot] and 10 guests
