Do they make an adapter for this?
The connector on the left is my new NiMh battery for my nitro rc10gt. The connector on the right is goes to the switch for the cars electronics. So its the normal place where the batt plugs in, just connector issues, because nimh batt.
These need to connect, but how?
Interestingly, the 3rd connector is female and when I plug the batt into it, everything works, but only when the switch is in the off position.
- Has thanked: 10 times
- Been thanked: 447 times
Re: Do they make an adapter for this?
you can buy a male to male adapter to connect these two connectors. you may have to trim the small keying feature on the connector on the right.
- slotcarrod
- Been thanked: 41 times
Cut the tabb off the Futaba plug on the right to plug into any other modern system! For the switch, unscrew your switch plate, rotate plate 180, place screws and tighten!
Rod Littau
I'm not sure we're reading each other right.slotcarrod wrote:Cut the tabb off the Futaba plug on the right to plug into any other modern system! For the switch, unscrew your switch plate, rotate plate 180, place screws and tighten!
The new switch I got today has 3 connections. The one shown on the right in the pic, a female connector (I assume for charging), and one that looks like the left that's plugged into the receiver. Then there's the batt, as shown on the left.
Tried searching for that adapter, no luck. Will continue looking.
- Lonestar
- Has thanked: 626 times
- Been thanked: 166 times
I don't understand the description of your problem, but no matter what, screw adapters, they add unreliability... pull out the soldering iron and do your own connections. It's not like we're talking multiphased systems here, it's just a + and a -...
Paul
Paul
But then my battery won't be removable!Lonestar wrote:I don't understand the description of your problem, but no matter what, screw adapters, they add unreliability... pull out the soldering iron and do your own connections. It's not like we're talking multiphased systems here, it's just a + and a -...
Paul
- Lonestar
what I meant is install your own connectors. One male, one female.Justin428 wrote:But then my battery won't be removable!Lonestar wrote:I don't understand the description of your problem, but no matter what, screw adapters, they add unreliability... pull out the soldering iron and do your own connections. It's not like we're talking multiphased systems here, it's just a + and a -...
Paul
- Has thanked: 822 times
- Been thanked: 2418 times
Ok...the switch you have should have one female and two male (shown above).Justin428 wrote:slotcarrod wrote: The new switch I got today has 3 connections. The one shown on the right in the pic, a female connector (I assume for charging), and one that looks like the left that's plugged into the receiver. Then there's the batt, as shown on the left.
One male plugs into the receiver. Sometimes it is red in color
The lone female accepts the battery pack
The final male is for charging.
If there is a tab in the way of plugging the connector in, carefully trim it off and align the colors
Factory Works website
Here is a sample
- Been thanked: 4 times
Just get rid of the switch and make a simple connector. Plug it in to turn it on and unplug it to turn it off. Switches are unreliable, especially on a nitro car, and a bad switch on a nitro car can really ruin your day.
- 652 Views
Last post by vintage88
- 674 Views
- 833 Views
Last post by sheriff
- 1486 Views
Last post by Sixtysixdeuce
- 751 Views
Last post by Y'ernat Al
- 203 Views
Last post by Oliver77
- 1128 Views
Last post by CAT3K
- 87 Views
Last post by GreenBar0n
