what degree rear mounts to use with b4 hubs?
Ok i am using b4.1 hubs with b44 cva's ont the rear i want to change my arm mounts to black ones and i found a set of andy's 3degree.but i cant find out any info on the b4 hubs as far as what degrees they are.i cant even see where the rear toe comes from on a b4.so i know the toe on a rc10 comes from the mounts and i believe its 3degrees right?so i should get the 3degree andys black mounts right? Does the stock b4 hubs have toe? Thanks for any help
My pop always said i had to many iron's in the fire
Re: what degree rear mounts to use with b4 hubs?
Will the 3degree work?
Rear toe on a B4 is in the inner mounts. O on the outer hub.. On a RC0 with stock mounts the way to go is buy "wollered" out B4.1 Worlds aluminun hub carriers " slop on the hinge pin hole" makes them almost free" so 1.5 innner and .5 on the outer is a good start on most current high bite tracks.
- 663 Views
Last post by joel45acp
- 482 Views
Last post by RCveteran
- 1912 Views
Last post by DaveM
- 682 Views
Last post by JK Racing
- 41 Replies
- 4594 Views
Last post by DaveM
- 3314 Views
- 1503 Views
Last post by cowsrneat2002
- 630 Views
Last post by juicedcoupe
Users browsing this forum: Google Adsense [Bot] and 7 guests
