Marui samurai gearbox is rough
My latest restoration project is a samurai, but I'm stuck at the gearbox assembly. Can't get it to turn smoothly. Everything is cleaned, in good shape and ballbearings are fitted. As soon as I try to tighten the screws that hold the casing together it pretty much seizes. At least the axle where the chain drive goes. Anyone had the same problem?
- RC10th
- Has thanked: 40 times
- Been thanked: 1015 times
Re: Marui samurai gearbox is rough
Are there any witness marks on the trans case to show what is rubbing. Are the bearings fully seated? Do all the bearings spin free in the case?
Try assembling the trans with only one component (i.e. diff) and see if it's tight, if not try another component (top shaft or idler).
Thanks for the input General! Got it working now. It was some bearings that fit over some small tubes (very tight fit) that seized when fitted without a little bit of margin sideways. Can't explain better, only have manual in Japanese so I don't know what the parts are called;) Thanks for pushing this along
- 1162 Views
Last post by dahlelama
- 43 Replies
- 5151 Views
Last post by DennisM
- 19 Replies
- 3736 Views
Last post by naushad
- 29 Replies
- 2639 Views
Last post by Mad Racer
- 19 Replies
- 6108 Views
Last post by optimaforever
- 2206 Views
Last post by civilguy
- 2225 Views
Last post by Lonestar
- 31 Replies
- 4397 Views
Last post by Dadio
