novak 1 esc wiring help
I purchased a RC10 graphite buggy last week, the previous owner cut the receiver plug off the esc. I want to fix the esc to see if it works, but not sure about the wires. There are two black wires and one red wire. Does anyone know which wires are the signal, positive, and negative wires? Thanks for any help you can provide. Mike
- Has thanked: 822 times
- Been thanked: 2418 times
Re: novak 1 esc wiring help
If they are still molded together it will be black black red. Red is positive, center is negative, and outside black is signal. It had an airtronics connector on it with those colors. Doesn't matter but that's why it is like that
Factory Works website
Thank you, I didn't want to burn up anything in case the esc is still good.
The negative and signal technically wouldn't hurt anything if reversed it just wouldn't work. The red is the important one
- 668 Views
Last post by fleetwood472
- 2279 Views
Last post by Cplus
- 143 Views
Last post by ZED32
- 1737 Views
Last post by teman
- 1405 Views
- 22 Replies
- 2754 Views
Last post by REMJ666
- 1718 Views
Last post by Asso_man!
- 3863 Views
Last post by Tadracket
