Mid-Motor Stealth transmission
I have been coming up with some ideas for a dirt oval project and was wondering about mid-motor conversions for a gold pan. Does the slipper shaft have to come out the other side of the case so it runs the right way? I have been looking for examples but am having trouble on the details, 'WTF buggy' thread shows the motor plate flipped. Would it bet better to get a gt tranny and work with that? I have been messing around with placement with a 6-gear trans and battery placement gets tough, and servo mounting will be creative to say the least.
thanks in advance
tom
thanks in advance
tom
Tom
- THEYTOOKMYTHUMB
- Has thanked: 2122 times
- Been thanked: 1346 times
Re: Mid-Motor Stealth transmission
I'm not sure if it will answer all your questions, but here's a good start. You may also search PBRallstar's builds. He posts in this thread also so you can just go into his profile and search his posts. Someone else may have a more specific build, but I can't think of one right off.
http://www.rc10talk.com/viewtopic.php?f=38&t=27077
- Phin
- Has thanked: 61 times
- Been thanked: 182 times
If you filp the transmission to mid motor you have to flip the top shaft to keep the motor's pinion on the same side of the car it is on a rear motor car.
However there's also the alternative options of reversing the rotation of the motor on some brushless motors/esc; running an idler between the pinion and spur; or using a Hyperdrive belt set up to move the pinion and spur to the left side of the car.
Almost like running a jack shaft.Phin wrote:If you filp the transmission to mid motor you have to flip the top shaft to keep the motor's pinion on the same side of the car it is on a rear motor car.
Tom
- SRTracer121
not perfect example but here is my 2.25 setup
a fellow local's rc10 based lto setup
you could always switch to a hyper drive in mid motor as it runs backwards anyway.
- 550 Views
- 1927 Views
Last post by adam lancia
- 2082 Views
Last post by Phin
- 951 Views
Last post by KidAgain
- 1086 Views
Last post by Texas_Man2011
- 2493 Views
Last post by n20capri
- 967 Views
Last post by Erich Reichert
- 22 Replies
- 3936 Views
Last post by Chemical
Users browsing this forum: No registered users and 16 guests
