6 gear transmission - idler gears
I you could get a set of new idler gears made of delrin how much would you be willing to pay for them??
if not delrin then what other suitable replacement material?
Tom
Re: 6 gear transmission - idler gears
I believe ur breaking some rules with this question... i would go read the rules ur not aloud to ask "what is it worth " type questions and if you are trying to make them to sell you should wait until you have bst permissions... not trying to be a d-bag it's. Just the rules here
no thats not what i am asking at all i was asking to see if it would be worth while to give an old retired machinist something to do and maybe make a little money for himself. was asking if any one would be interested in buying some to make it a worth while endeavor, just seeing if there is an interest or not.
maybe i should just ask a different way
here goes
Is delrin the most suitable replacement material for idler gears ????
here goes
Tom
- Has thanked: 822 times
- Been thanked: 2418 times
I am not a plastics guy all I know is the Delrin gears that thorp made for many cars are still sought after today. Are there better materials? Not sure. But Delrin was popular.
People play jump rope with the value rule all the time, I don't see it as a problem if you have BST access and name a price but to ask what we are willing to pay is against the rules. If I said $25 a set I'd be screwing the guy that says $15 and the guy saying $40 is screwing both of us. It's better if we just don't "bid" value.
That being said.....if you build them, people will buy them
Factory Works website
- Seabass
- Business Member
- Been thanked: 12 times
The best thing you could do is have some gears made from a few different types of material and give them a test to see which ones hold up. It would be terrible for you to have gears made from material then find out as soon as power is applied, the gears become toast.
I will add to your endeavor a bit too, find material that would hold the power of a mild brushless system. I know there are several guys here that have used mild brushless systems with 6 gear trannies with great success. I also know of some who have trashed gears using the same systems as well.
Good luck with the gears, I know there is some pretty complicated things that go into gears. As stated earlier, make them good and strong and you will get interest.
Jake
Jake
- Has thanked: 10 times
- Been thanked: 447 times
The original gears were nylon and later glass filled. The thorp 48 pitch idler gears were delrin. Any of those would be suitable. If you to select something like a Moly filled nylon it would provide some additional lubrication, but not sure how strong it is. Sterling drive products sells gear blank around 6 inches long but not sure if they have the right pitch tooth count or material but that could really cut down on work required.
yeah i am sorry if i am causing a stir. i was trying to figure out a break even point. i was not looking to make any money from this endeavor. just trying to keep my 6 gears running without having to buy a used tranny for parts every time. I have found 2 foot delrin rod to make it, not really the cost factor, paying for someone elses time is the issue. thanks for the responses. i was hoping that it wouldn't cost any more then $8-10 for a pair with replacement screws and the allen wrench.
Tom
That would be an amazing price. Stocks were $5 for comparison.
Not trying to bust yer diff balls just trying to make sure you understand why we have the rules as well as letting you know they are there. Im sure they will be a hit!
i haven't given up on making these gears. just saw NIP black idler gears with wrench and scews on the bay go for $25 i wouldn't pay that
have been talking to a couple of plastic dealers and they said i would need a CAD drawing of the gear to see what it would take to make it, i could probably draft it up by hand but i didn't pursue it much further because they were the middle men and not the actual manufacturer.
Tom
- 1313 Views
Last post by JRG
- 1239 Views
Last post by 85Edinger
- 544 Views
Last post by adam lancia
- 776 Views
Last post by Brat
- 636 Views
Last post by treehugger
- 3161 Views
Last post by DMAT
- 1251 Views
Last post by superfly
- 1136 Views
Last post by templeofspeed
Users browsing this forum: DotNetDotCom.org [Bot] and 26 guests
