Gold Pan A Stamp
Gold Pan A Stamp
What is the best way to clean a stained chassis ??? Mine is a gold chassis and there seems to be some dark areas on it...Otherwise it is in great shape...And i have to believe it is some sort of stain...What is the best way to rejuvinate rubber tires ????
- Has thanked: 10 times
- Been thanked: 447 times
Re: Gold Pan A Stamp
just soap and water will clean up grease and dirt, dish detergent usually. You can try acetone, and wd40 to see if the stain is oil, gum or dye based to try and get it off, but other than that, if it's stained, it's stained. Don't use anything like super clean or simple green or any other caustic cleaner, that will remove the anodizing. stick with solvents or soaps.
Thanks for the tip...I will try the wd40 first...
- 2171 Views
Last post by jeepy2013
- 148 Replies
- 3204 Views
Last post by GreenBar0n
- 24 Replies
- 3343 Views
Last post by pcrussell50
- 1219 Views
Last post by gumbajv
- 38 Replies
- 4580 Views
Last post by UltraHIVE
- 114 Views
Last post by morrisey0
- 1554 Views
Last post by DaveM
- 578 Views
Last post by mikea96
Users browsing this forum: No registered users and 45 guests
