Adjustable motor mount
Has anyone used one of these type before? If so how does it compare to the old crp 2 piece fiberglass one, is it a p.i.t.a. being just one piece?
http://www.ebay.com/itm/Tamiya-Brat-Adjustable-Motor-Mount-CB18M01-slide-the-motor-to-fit-any-gear-/140867547689?pt=Radio_Control_Parts_Accessories&hash=item20cc5c3229
Thanks for any insight
- Has thanked: 822 times
- Been thanked: 2418 times
Re: Adjustable motor mount
Looks like a nice setup but you don't have a easy micro adjustment. On the crp you could get the gears to mesh and then back it off, on this one you may have to install, check, uninstall, recheck etc. Still, it looks like a nice piece - i'd hit it
Factory Works website
- Mad Racer
I looked at that one & the other one buy CP racing I think.
I don't think it allows to go higher in pinions like what I wanted for my Frog with a stock 540.
My Topic is here along with the 5 I purchased for myself & others. They work so well. Just loosen the screw nuts & adjust mesh easy through the Lexan cover. Very well made too.
http://www.rc10talk.com/viewtopic.php?f=32&t=27020
- Mad Racer
It bolts to the motor with the counter sunk screws provided and makes the plate flush. The 2 long screw are counter sunk as well and slide up down on the other side of the plate. This allows the motor to move up & down. The 2 long screws just bolt up through the grear case as normal.
All up a very well made & effective mod for any Frog chassis.
If you can understand my description.
- Mad Racer
Yes it it is rock solid.
- 446 Views
Last post by UltraHIVE
- 549 Views
Last post by Mr. ED
- 502 Views
Last post by GoldRush
- 1763 Views
Last post by klavy69
- 1092 Views
Last post by pottok
- 2423 Views
Last post by Lonestar
- 19 Replies
- 1341 Views
Last post by slotcarrod
- 21 Replies
- 2634 Views
Last post by Justjoe
