Losi XX Kinwald
- geeforce59
- geeforce59
- geeforce59
Re: Losi XX CR Kinwald???
Just need to replace the broken front arms and look for a appropriate servo horn and linkage.
- License2iLL
not a bad score
Glad to be back in this hobby so many many years later. To see new things and to recollect on ALL cool vintage models!
As well as to BUILD :
http://www.rc10talk.com/viewtopic.php?t=27591
http://www.rc10talk.com/viewtopic.php?f=27&t=33429
- slapshot1979
Looks like a good start. runner or shelf??
- geeforce59
- slapshot1979
If you wern't so far Id ship you a beater motor plate to put that one back in the box
- slapshot1979
You just finished that build in 3 minutes..
Love that motor
Love that motor
- geeforce59
Well in fact a good member here gave this car and he shipped it in the Philippines and during my vacation i was able to clean and inspect the car.
Took some photos without the arms and brought it with here in Saudi Arabia and rebuilt installed a new front arms and so on.
The only thing left is the servo horn and linkage which i will snatch it to my XXX CR car while im waiting for the servo linkage parts that i ordered.
It took me about a month before i replaced the arms! i just came back last week!
- FasterLouder
- Has thanked: 10 times
- Been thanked: 51 times
Re: Losi XX Kinwald
That's great to see a Kinwald being used as a runner,instead of languishing on a shelf (like mine)!
I'm talking with a printer about reproducing my decal stash and I have a mint XX CR Kinwald sheet that will be included,I'll let you know how it goes.
All The Way Alive
- DerbyDan
- Been thanked: 17 times
Re: Losi XX Kinwald
Great stuff! I love running my KW - I can't wait until next year's outdoor season when i'll race it again
Your car does have some unusual parts on it for a Kinwald - it has the earlier style front (wider) shock tower, also the slider driveshafts was a feature of the very first issue Double Xs - but I understand they were sometimes used by drivers of later variants as a tuning option, apparently because they tend to 'bind' in their slider action it has the effect of reducing rear end grip, making the car more lively (some drivers felt the XX was too safe to drive). Your car has the CR rear end (correct for a KW) but has the hub mouldings from the original XX rear end - so you must have alot of toe-in, as the CR rear pivot plate has built in toe aswell!
A tuning trick that I used to use for racing on tight indoor carpet tracks was to run flipped XX hubs on a CR rear end - this gave 0 deg toe & made the car really lively
- mytimac
- Business Member
- Has thanked: 7 times
- Been thanked: 54 times
Re: Losi XX Kinwald
Just to clear up potential confusion on the sliders for XX. The bushing only versions of the XX came with the sliders. The bushing versions came after the initial XX release.
"With the realease of the new Double-X and Double-XT kits with bushings came a plastic differential for the Double-X transmission. This new differential is designed to use the plastic "slider" type drive shafts. This was a design that many thought was incorporated only for cost reasons, but the truth is that there are conditions in which the plastic drive shafts out-perform the dogbone type drive shafts. Once the team drivers started using the slider drive shafts, Team Losi decided to offer a conversion kit so that anyone with a Double-X transmission could try them out.
The fact that the plastic differential and outdrives are less than ½ the weight of the standard steel outdrives and dogbones makes them ideal for stock class racing. Less rotating weight results in quicker acceleration, which is important in the stock class. The sliders also work in the modified class. The biggest advantage comes when the track is extra slick, or extremely bumpy. If the track is bumpy and slick, all the better."
It will fit any Double-X or Double-X retro-fit transmission.
- bearrickster
- Been thanked: 5 times
Re: Losi XX Kinwald
I put the sliders on it, when I got the car the transmission was completely destroyed. that was all I had at the time. and didn't have the money to buy all of the parts to put it back 100% KW. its my fault
- FasterLouder
Re: Losi XX Kinwald
Yes sir,use thew sliders and you're forced to use plastic diff outdrives!
Needless to say,any durability is long gone.
All The Way Alive
- jamin
- Been thanked: 24 times
Re: Losi XX Kinwald
I always ran plastic outdrives and sliders on my XX4 to reduce the rotating weight of the transmission as there is a lot of energy lost with those three belts...
Team Losi: XX-CR | XXT | XXT-CR Graphite+ | XX4 | Street Weapon IWC Edition
- 1388 Views
Last post by LosiXXkid
- 2637 Views
Last post by mikea96
- 1089 Views
Last post by treehugger
- 60 Replies
- 8297 Views
Last post by DerbyDan
- 3384 Views
Last post by keyesgood
- 44 Replies
- 9146 Views
- 77 Replies
- 11850 Views
Last post by mikesofunny
- 1844 Views
Last post by rctenracer
Users browsing this forum: No registered users and 17 guests
