Stock motor lathe
- EvolutionRevolution
- Has thanked: 20 times
- Been thanked: 36 times
Stock motor lathe
Anyone knows what is a good stock (non-rebuildable) motor lathe?
Or should I just stick with comm sticks and new brushes for motors that old...?
- Mad Racer
Re: Stock motor lathe
They are a lot harder to find then the mod lathes!!!
I remember opening up the stock motors and turning the comms on a mod lathe.
Just the 2 little bent tabs holding it together right.
Thanks. I've got a nice automated mod motor lathe (picked it up for not much when a local shop was blowing them out), but stock lathes are hard to find and often expensive.
How hard is it to bend the tabs on the motor housing back into place?
- wait a minute
Twister is the best at that time when you could tru comms in the can.
wait a minute
From what I remember...
Take out brushes and springs.
A thin bladed screw driver could pry up the tabs. Be careful you dont stab yourself!
No need to pry them too much. Hold the motor housing and tap the pinion shaft lightly on a workbench.
Should pop right out.
Then putting it back would use a small punch tool. Give the punch a rap with a hammer to bend the tab down.
Best to punch on the end of the tab just like it was.
- wait a minute
the one thing i remember i hated was the spring post that were not pre threaded and you had to pound them back in. i think it was cobra that came out with aftermarket ones.
wait a minute
- Hcp22
- Has thanked: 33 times
- Been thanked: 16 times
- Lonestar
- Has thanked: 626 times
- Been thanked: 166 times
minreg wrote:I remember opening up the stock motors and turning the comms on a mod lathe.
- 184 Views
Last post by Frankentruck
- 907 Views
Last post by RC10th
- 1484 Views
Last post by Hotrodvw
- 1856 Views
Last post by MelvinsArmy
- 412 Views
Last post by templeofspeed
- 857 Views
Last post by Brat
- 958 Views
Last post by JK Racing
- 2692 Views
Last post by captaindemo17
