Can you fit Clod Buster Wheels/Tyres to Blackfoot?
Anyone know the answer to the question of whether you can fit original Clod Buster wheels/tyres to the original Blackfoot and, if so, please could they let me know how it is done/which parts are necessary?
Thanks a lot.
Thanks a lot.
- Has thanked: 28 times
- Been thanked: 957 times
Re: Can you fit Clod Buster Wheels/Tyres to Blackfoot?
Easiest thing to do would be getting a set of imex jumbo tires and dual rims. Finding them isn't that easy though.
Another thing you can do is to modify a blackfoot rim to fit inside the clod rim, then just glue it and screw it. I did it a couple years ago to a pair to help my old midnight pumpkin get through the snow.
- Mr. ED
- Has thanked: 58 times
- Been thanked: 56 times
I remember an old add in RCCA showing a amonster beetle or something along those lines with clodbuster wheels. Could have been IMEX? I think the same add also had a listing with lots of chromed plastic parts and light kits.
- shodog
- Has thanked: 3 times
- Been thanked: 86 times
It was common to use a set of marui big bear tires and rims on the blackfoot. They look similar to a clods, just not quite as big.
- uniquenamehere
Be careful of the diff/driveshafts if you do mount them. They're easily damaged! Get a Thorp ball diff/dogbones if you can find one.
- MelvinsArmy
I'm pretty sure adapters were made just for this.
As for the Big Bear tires, I remember that was a popular upgrade because the Big Bear tires had more bite, I believe the rubber is softer than the Blackfoot tires.
epoxy that diff if you want it to move for more then a minute or two.
i wouldn't waste a thorpe diff on this, just lock the stocker and get some new frog cvd's.
- Diggley
I'd like to find a set of adapters for the Clod to Blackfoot conversion....The Big Bear stuff is getting pricey.Lowgear wrote:It was popular enough that JG made front and rear adapters in order to achieve such a thing.
Projects and shelfers:
- Lowgear
- Has thanked: 78 times
- Been thanked: 596 times
I don't recall any company making Clod to Blackfoot adapters. I'm not saying there isn't any, just that I don't specifically know of any.
Is this something you plan to run? If it were me, I would choose Midnight Pumpkin / Lunch Box etc... wheels for a number of reasons.
- Mr. ED
he meant clod wheels to blackfoot axles, not the other way around
- Lowgear
If you're referring to me I don't see where I confused it?
Anyway, what I would do is go over to Tamiya Club and see if there are any examples of Blackfoots with Clod wheels to see how they did it.
Thanks for all the comments/suggestions/etc. Much appreciated. By way of background, I'm hoping to put together another blackfoot with a few funky parts like trackmaster gearbox, hot trick style chassis, period aluminium shocks, etc, and wanted to add some wheels which were slightly more "monster" truck style than the original blackfoot ones. I'll have a look around as per the suggesions above.
- Has thanked: 1013 times
- Been thanked: 472 times
Bitd I took a pair of tamiya mount foam on road tires and stuck my clod tires right over them. They friction fit just great and ran for almost a whole 1200 mah pack before the splines on the drive shafts became smooth.
I do not recommend clod tires on a vintage Blackfoot.
- 30 Replies
- 6810 Views
Last post by markbt73
- 3102 Views
Last post by longboardnj
- 1552 Views
Last post by SFC K
- 1237 Views
Last post by Hemiclod
- 918 Views
Last post by DoubleDareLover
- 63 Views
Last post by Lowgear
- 561 Views
Last post by 59burst
- 934 Views
Last post by templeofspeed
Users browsing this forum: Amazon [Bot], Tbot [Bot] and 4 guests
