Kyosho Slingshot rear belt help needed
I finally killed the rear belt on my Slingshot today. I've found one on the bay for way more than I would like to pay. Does anyone have any info on another that will fit from either another Kyosho car or perhaps another manufacturer.
Re: Kyosho Slingshot rear belt help needed
The belt has 67 teeth. I believe it is a 3mm pitch belt and it is 5mm wide.
- Hcp22
- Has thanked: 33 times
- Been thanked: 16 times
Shouldn’t be any problem to find a replacement, all Kyosho belts are industrial standard!
I've counted mine 4 separate times, 67 looks to be the count. What car did the belt with 64 teeth come from? I would like to find the industrial equivalent to save a bit of coin if I can. The markings on the belt have worn off with time.
- LTO_Dave
- Has thanked: 46 times
- Been thanked: 225 times
The part number from my Slingshot manual is OR-10 if it helps. My rear belt has Bridgestone S3M201 Made In USA 49 printed on it and it has 67 teeth.
- murphy3428
- DennisM
- Has thanked: 30 times
- Been thanked: 64 times
I could only find 6mm beltsmurphy3428 wrote:You could try here http://www.sdp-si.com/web/html/products.htm
https://sdp-si.com/eStore/PartDetail.asp?Opener=Group&PartID=6617&GroupID=342
Gone fishing
- DennisM
It came from an onroad kit like this: http://www.rctech.net/forum/attachments/r-c-items-sale-trade/875817d1328816088-new-kyosho-f-ten-f10-f-10-new-1-8-1-9-1-10-nitro-nib-imag0062.jpgProXL wrote:I've counted mine 4 separate times, 67 looks to be the count. What car did the belt with 64 teeth come from? I would like to find the industrial equivalent to save a bit of coin if I can. The markings on the belt have worn off with time.
Gone fishing
- Hcp22
Appreciate the assistance, still no luck on finding an actual supplier for the belt in question, even using the part number from the belt itself. I'm going to have to do a bit more research and make a few phone calls to see if I can track something down.
- Has thanked: 28 times
- Been thanked: 957 times
that's nothing a razor blade couldn't fix.DennisM wrote:I could only find 6mm beltsmurphy3428 wrote:You could try here http://www.sdp-si.com/web/html/products.htm
- Has thanked: 10 times
- Been thanked: 447 times
yeah, this thread has a couple pictures of my belt cutting jig, second page:
http://www.rc10talk.com/viewtopic.php?f=29&t=22335&hilit=belt+lathe&start=15
I ordered the part of ebay, cost an arm and 1/2 a leg to get the car going. I'm going to order a couple from SDI next week and cut them to size.
- 3473 Views
Last post by tintin74
- 20 Replies
- 2981 Views
Last post by SFC K
- 423 Views
Last post by JK Racing
- 2155 Views
Last post by Kyoshojoe
- 449 Views
Last post by ProXL
- 2605 Views
Last post by Lonestar
- 1521 Views
- 35 Replies
- 1952 Views
Users browsing this forum: No registered users and 16 guests
