Dog Bone Issue!!!
Dog Bone Issue!!!
This is the RC10T I picked up and I'm just running it as a runner for some play time for now, but for some reason the Dog Bone popped out on one side and now it seems like it's to short and it doesn't fit. I've taken both sides apart to compare them and they look the same to me. They both have a small spacer on the transmission hub and springs in the wheel hubs, but one just doesn't fit? Any suggestions?
RC10talk.com is like a bad accident, I just can't stop looking at it...
- CamplinP
Re: Dog Bone Issue!!!
Try loosening the spring tension. It looks like the collars are pretty far down. The rear arms should be about parallel with the ground. You might need to limit how far the shocks travel also so they don't fall out on the jumps.
- Been thanked: 22 times
IT .HAS the buggy rear hub carriers on it,Not the THE 10t REAR HUB carriers.You could try orings in the tranny outdrives to help keep them in.DON
Well it wasn't missing, but once you pointed that out I did see where one hub stuck out a lot further then the other. I pulled the wheel and this is what I found. I just hammered it back in place and now it's all good until it happens again... This poor truck has been trashed and beat badly, but it still runs and drives. Thanks for the help guys...Charlie don't surf wrote:Look closely, the right outer axle stub cup is missing or broken in half-
Well that explains it then, that bushing is screwed anyways. I'll keep my eye out for some cheap parts and try to fix it the right way. Thanks again for the help.
Wow, that's awesome, thanks...Charlie don't surf wrote:Pm me your addy, I'll send you some-
- 1842 Views
Last post by Mad Racer
- 2175 Views
Last post by THUNDERSTRIKE1
- 1402 Views
Last post by JK Racing
- 552 Views
Last post by vintage racer
- 1450 Views
Last post by JosephS
- 629 Views
Last post by BACK_AT_IT
- 685 Views
Last post by klavy69
- 1213 Views
Last post by teman
