RC10 Stealth Slipper question
Can I use a B4 slipper assembly onto an original upper gear on a stealth? It seems that the original RC10 slipper pad parts are not plentiful (and more costly).
Any suggestions? Thank you!
Re: RC10 Stealth Slipper question
End result considering longevity, price, what do you think is better?
- Has thanked: 7 times
- Been thanked: 41 times
- Lonestar
- Has thanked: 626 times
- Been thanked: 166 times
Well, it is better, but not necessarily worth it... for most mills and if you have one already, the stock rc10 slipper is just fine... if you're building a trans from the ground up, then it makes more sense to use a B4's as the parts are more widely available and the performance is certainly no less
Paul
Paul
- soniccj5
I have been running the original slipper on my RPM 2.65 stealth with a 10.5 brushless without any issues. I would like to upgrade to the b4 at some point.
- Been thanked: 87 times
Tower still has the b3/t3 slipper parts on hand for around 18 bucks. The friction area is about the same as the b4 set up just cheaper.
part numbers are 9253, 9252, and 9251
- Claymore5150
I like running a B4 assembly because there are so many B4s in our club and we can mix/match our spurs for testing.
Parts are carried at the LHS.
Itchy Trigger Finger and RC Throttle Junkie
R.O.C.C.K. Proud Member
B.B.R.C. Proud Member
94CErunner/T2runner/2wd Slash LCG/
My shortcourse 10T has the 2.25 stealth and stock slipper. The frankenbuggy has the b4 trans and slipper. HUGE advantage to the old one is I don't have to readjust the slipper from scratch after a gear change.
Nick
Nick
New B4 parts can be found on e-bay for around $10 (slipper plates, pads, spur, hardware) -pulled new from kits. Just pick up a layshaft (same source) for around $5. The whole assy shipped for less than $20 is pretty typical. -Jeff
- 1004 Views
Last post by KidAgain
- 1266 Views
Last post by mdutcher
- 2752 Views
Last post by CBR240
- 1340 Views
- 402 Views
Last post by Lonestar
- 1351 Views
Last post by hugger19
- 639 Views
Last post by BWX
- 1131 Views
Last post by JosephS
Users browsing this forum: Ahrefs [Bot], Google [Bot], Google Adsense [Bot] and 8 guests
