Search terms ignored
- flipwils11
- Been thanked: 15 times
I'm not sure why some of the most common (and to me relevant) search terms seem to be exempted on this board. Things like "stealth", "tires", and "2.25", the engine won't accept. It usually leaves me scratching my head for a while like a guessing game to outthink the search terms ommitter to get what I need.
Any reason why some of these terms are not allowed?
Re: Search terms ignored
Because the stealth tires were not 2.25. The word tires is just too general-
Those words appear like 8000-12000 times, refine your search term to something more specific and choose a specific area like temples tech, or the buggy forum only-
2.25 stealth transmission searched in the RC10 buggy forum http://www.rc10talk.com/search.php?keywords=2.25+stealth+transmission&terms=all&author=&sc=1&sf=all&sk=t&sd=d&sr=posts&st=0&ch=300&t=0&submit=Search
2.25 stealth transmission searched in Temples Tech http://www.rc10talk.com/search.php?keywords=2.25+stealth+transmission&terms=all&author=&fid[]=38&sc=1&sf=all&sk=t&sd=d&sr=posts&st=0&ch=300&t=0&submit=Search
Edinger tires in the RC10 buggy forum http://www.rc10talk.com/search.php?keywords=edinger+tires&terms=all&author=&fid[]=35&sc=1&sf=all&sk=t&sd=d&sr=posts&st=0&ch=300&t=0&submit=Search
Edinger tires in Temples tech http://www.rc10talk.com/search.php?keywords=edinger+tires&terms=all&author=&fid[]=38&sc=1&sf=all&sk=t&sd=d&sr=posts&st=0&ch=300&t=0&submit=Search
Even more specific by author in the RC10 Buggy forum- http://www.rc10talk.com/search.php?keywords=edinger+tires+&terms=all&author=slotcarrod&fid[]=35&sc=1&sf=all&sk=t&sd=d&sr=posts&st=0&ch=300&t=0&submit=Search
- Has thanked: 10 times
- Been thanked: 447 times
right, you would get pretty much every thread if you are looking for more 'common' words.
try this, go to google search, in the advanced search, add the search terms and then select at the website 'www.rc10talk.com'. it will search all relevant posts with the exact words with no omissions.
it's more bothersome to me when I'm looking for B2 or B3 or simpler 2 letter words that get omitted.
this isn't rc10talk specific, and this place actually has a decent search engine. I go to forums where you are better off just reading every thread rather than searching ANYTHING.
- flipwils11
I've done that. I merely included "tires" as an example of a perfectly good term that is not included either.
I was searching for "stealth +2.25" in temple's tech subsection, which to me should be very specific.
I am well versed in search logic and Boolean search terms (or the shorthand +/- operators). If the user is searching for specific terms within a subsection of the forum perhaps the engine could suppress the ignore logic. But if someone searches for tires on the entire forum I agree the user should be prompted to try different terms.
So what is the question, is it answer to the dropped search request be changed to "the search terms are too ambiguous" in leiu of "item does not exist" ? I'm having trouble following-
- flipwils11
My proposed changes in pseudo-code:
IF FORUM = ALL
THEN SEARCH TERM OVERRIDE = TRUE ## default
ELSIF FORUM = SUBFORUM+
THEN SEARCH TERM OVERRIDE = FALSE
ELSE # catch-all case
IF FORUM = ALL
- Lowgear
- Has thanked: 78 times
- Been thanked: 596 times
Hey what do you want from free message board software that comes loaded with just about every instance of cPanel? It does an alright job for what it is. Although I agree that its annoying when it omits search terms that it deems too short or common even when they're not. Searching using Google helps but that only works with pages its indexed.
- 1113 Views
Last post by prp
- 669 Views
Last post by amx73
- 7098 Views
Last post by Tadracket
- 1271 Views
Last post by Ayk Viper
- 898 Views
Last post by mytimac
- 1342 Views
Last post by GTfour
- 2073 Views
Last post by prp
- 626 Views
Last post by mattxb
