Motor runs backwards??
Post Reply
jimbobarooney
Post by jimbobarooney »
Looking for some tech help today...
I'm installing electronics in my RC10 today. I"m using a Speedworks motor, Tekin 411 P2, Futaba 112 receiver and a Magnum Junior radio. I've installed everything and the motor runs backwards.
I tried using the servo reversing on the transmitter with no luck.
The ESC/receiver/radio combo I took from another car. It worked perfectly before I transferred it to this car.
I was wondering if somehow the stealth trans was put together incorrectly. But I've compared it to another car that is a known runner and it works properly.
I've double checked the polarity of the ESC to the battery, and ESC to the motor. Positive to positive, negative to negative. The only untested part of this setup is the motor. Before I installed it, I opened up the motor to clean it, everything looks good inside. Could it be a timing issue? I think that the timing can be adjusted. The plate that the endbell screws onto turns inside the motor can and I can rotate the endbell around. However there aren't any timing marks on the can to denote 0 degrees. Is it possible for the motor to run backwards if the timing isn't adjusted properly?
Has thanked: 28 times
Been thanked: 957 times
Re: Motor runs backwards??
you might have flipped the endbell around 180 degrees when you put it back together.
Endbell is on backwards
jimbobarooney
IT'S ALIVE - and running the right direction!
Thanks!
Post Reply
  • Why does my motor only rotate backwards?
    by mamadoesntletme » » in Modern Electronics
    Last post by mamadoesntletme
  • Motor smokes but still runs?
    by 85Edinger » » in Vintage Electronics
    Last post by 85Edinger
  • Am I wiring my esc backwards?
    by ZED32 » » in Vintage Electronics
    Last post by ZED32
  • Who still runs old tires?
    by fredswain » » in R/C Off-Topic / Chit-Chat
    Last post by Lowgear
  • Imminent's RC10CE - It still runs?!
    by ImminentFailure » » in RC10 Buggy Forum
    Last post by ImminentFailure
  • 1/10 4wd buggy, who runs'em?
    by kaiser » » in Off-Topic / Chit-Chat
    Last post by kink
  • rc10 bomber runs
    by knucklebuster » » in Racing News / Get-Togethers
    Last post by Kayne
  • What percentage of your collection actually runs?
    by Coelacanth » » in Off-Topic / Chit-Chat
    Last post by GAMMACRUSH
