JRX2 5 link help with data
- sgirouard
I'm looking at trying to fabricate some 5 link suspension parts for a little project.
Does anyone know the distance (middle of hole to middle of hole) of the 4 links (not the turnbuckle).
I'm looking at possibly making aluminum links, similar to the Tamiya Avante or a crawler. I'm thinking of trying to eliminate the slop.
- bearrickster
- Been thanked: 5 times
Re: JRX2 5 link help with data
side lower link 3 3/4
side upper link 3 1/8
links out to the wheels 2 3/4
- GJW
you new that off by heart hey rick alloy links keen to see what you come up with mate
- bearrickster
no my jrx2 beach buggy was sitting here on my computer stand, and a tape messureGJW wrote:you new that off by heart hey rick alloy links keen to see what you come up with mate
- sgirouard
I'm going to use 1/4" aluminum tube, 6-32 threaded rod, 2 nuts and 2 rod ends.
I'm concerned that the links out to the wheels will be too wide and that I won't find a ball link to fit the rear hinge pins. But we'll see.
- losiXXXman
That should take care of some slop. Eliminating flex in the links at least.
- sgirouard
Yeah. I was looking at pictures of the avante rerere..whatever LOL. And the linkages and said, hey why not do something like that for the X2
- Has thanked: 28 times
- Been thanked: 957 times
i made a set like that for an x2 back when i was in my crawler phase. they're kickin around in the basement somewhere. i never built anything to put them on, and i don't think i ever got around to drilling the holes for the lower shock mounts.
- sgirouard
How did it work Scr8p? As I've been sourcing the materials, I'm starting to thing the weight is going to be WAY too much. Only one way to find out but still.
i never had them mounted to a car. i tore down my x2 so i could measure the parts, reassembled it, then made the links later.
i used k&s 1/4" aluminum rod and dubro heavy duty 4-40 heim ends.
- RCveteran
- Has thanked: 4 times
- Been thanked: 100 times
Not fully what you guys are talking about but I started with upper links on this car which has since been sold. You could have used some Dubro rod ends as well. I did not get many laps on this car before it was sold but it worked well.
http://www.rc10talk.com/viewtopic.php?f=27&t=19073&hilit=racer+jrx2&start=15
if it wasn't for having to mount the shocks to the lower link, you could probably use tierods throughout the entire rear of the car and it have hold up ok.
- sgirouard
Thanks for the link RCveteran.
I was actually thinking about using a tie rod for the top link like what you did in order to keep the weight lower. I've been thinking that maybe the heavy links won't necessarily be a bad thing because it's shifting more weight over the wheels and forward and lowering the overall center of gravity.
- sgirouard
Does anyone *cough* Rick *cough* know the diameter of the inner and outer rear hinge pins?
Search-Fu is weak in me today. I just can't seem to find it.
- 954 Views
Last post by FasterLouder
- 23 Replies
- 4043 Views
Last post by Garage Hack
- 33 Replies
- 2947 Views
Last post by adam lancia
- 26 Replies
- 3664 Views
Last post by RCveteran
- 74 Replies
- 10540 Views
Last post by dldiaz
- 1222 Views
Last post by MelvinsArmy
- 960 Views
- 53 Replies
- 8935 Views
Last post by matt1ptkn
Users browsing this forum: Google Adsense [Bot] and 10 guests
