Carbon Fiber Sheets?
- mikedealer
anyone have a good source for 2.5 or 3mm sheets of carbon fiber? need a bunch of it, 18" x whatever long.. anyone ever find some on the "cheap" side lol? dragonplate seems expensive to me
Re: Carbon Fiber Sheets?
The standard going rate for say quasi-isotropic .117 3k plainweave is about $145 in the standard market, unless you get 10-100 panels. Cost is all about volume in cf
- mikedealer
- mikedealer
Component grade stuff can be cheaper. Jake found some from a one off guy, check with him and I'm sure he will get you the info!
- Been thanked: 289 times
I got some small scraps from an eBay store selling specifically carbon fiber stuff, for quite cheap. But we're talking 3 to 4" square. The bigger stuff was much more expensive.
- Seabass
- Business Member
- Been thanked: 12 times
I contacted a guy off eBay and had a specific panel made. I ended up with a 12 x 24, 3mm, double sided panel for $100. This is about as cheap as it gets. I can't tell you how many people I talked to including Reg on this subject.
The guy made the panel for me and when I got it, it was slightly warped. I was still able to use what he sent but I would have rathered a perfectly flat panel. When I say warped it wasn't bad but was noticable until I cut my parts out of it.
My panel was also filled with glass on the inside too to keep cost down. Hope this helps. Just remeber most of the panels I came across were only one sided. Make sure if you are looking for double sided, to read the descriptions carefully. I almost bought the wrong stuff when I first started looking.
- mikedealer
- THEYTOOKMYTHUMB
- Has thanked: 2122 times
- Been thanked: 1346 times
It blows my mind that there's not an easy source considering all the r/c parts that are made from it. Guess we shouldn't take CF parts so much for granted. Luckily I suck and can't fabricate anything on my own anyway...
- Seabass
- Business Member
mikedealer wrote:for this price i may go with a black fiberglass G10 lol.
This stuff is not cheap at all. I wish it was more affordable.
- Lowgear
- Has thanked: 78 times
- Been thanked: 597 times
I tried making an aluminum shock tower for a DS a number of years ago and I just came across it the other day. It looked like the only tool I used was a spork.THEYTOOKMYTHUMB wrote:It blows my mind that there's not an easy source considering all the r/c parts that are made from it. Guess we shouldn't take CF parts so much for granted. Luckily I suck and can't fabricate anything on my own anyway...
- THEYTOOKMYTHUMB
Shoulda used a thpoon. Not sure what it means, but I took a pic of a snake in my backyard about 4 years ago and it took a year of asking to get an I.D. on it. I had a couple of "experts" or "exthperths" tell me it was a brand new species! I was so excited because that meant I got to name it. "thnake" was my name. Imagine the snake world excitedly speaking of a thnake! Sadly it was identified as a common garden snake with an abnormal scale pattern (probably from the plutonium I keep buried in my backyard for when I perfect my flux capacitor). Now that I'm ending it, I'm not even sure what this post was in response to... Oh well, at least it kept my brain busy for a few seconds...Lowgear wrote:It looked like the only tool I used was a spork.
P.S.: I have a pic of the thnake on a back-up portable hard-drive around here somewhere. I'll have to look it up for reference.
- Has thanked: 7 times
- Been thanked: 41 times
- 645 Views
Last post by m_vice
- 564 Views
Last post by PBR Allstar
- 1353 Views
Last post by iPearl
- 462 Views
Last post by toolman72
- 3127 Views
Last post by fordtransman
- 256 Views
Last post by silvertriple
- 1337 Views
Last post by Bullfrog
- 1274 Views
Last post by trkneller
Users browsing this forum: No registered users and 15 guests
