3rd Channel Light Device?
- mikedealer
i want to add some "working" headlights to my car.
i plan to add some RAM aluminum headlights, which are:
http://www2.towerhobbies.com/cgi-bin/wti0001p?&I=LXDZ55&P=ML
Is there any way, to activate these remotely using a 3rd channel device?
Ive Been racking my brain, looking at robot building sites, airplane devices, etc etc, i can seem to find anything that would do it specifically.
Any ideas?
Any ideas?
- mikedealer
- mikedealer
i was actually thinking about making something like that with a micro servo, and building some sort of on/off metal contact on top,
basically gluing a small peice of flat plastic on top, and putting a flat screw in it with a + wire, then the top of the arm will have a folded peice of metal acting as a brush and when i turn the 3rd channel the metal will contact the screw turning it on.
Not sure if any of that made sense but it makes sense in my head lol.
Im gonna think about a switch setup all night now lol
- Has thanked: 15 times
- Been thanked: 35 times
dude there has gotta be some kinda little relay or tamiya semi-device that would be easier and less bulky than a microswitch activated by a servo.
i have a hard time thinking that there isnt a device like this for headlights:
http://www2.towerhobbies.com/cgi-bin/wti0001p?&I=LXDZ87&P=ML
you could probably just use that as a matter of fact.
- mikedealer
- Been thanked: 12 times
I wired up some lights on my RC-18, switched remotely, it is really easy to do.
Use the internal circiut board from a servo as a switch.
Solder 2 resistors across the leads to the potentiometer, or just ca the pot at neutral. wire up your lights to the output for the servo motor and there you have it.
I am using LED, so they do not take much power. I set the end points on my third channel to only allow "travel" in one direction to prevent reverse voltage to the LED. If you are using standard bulbs this is probably not necessary. Using the EPA in the other direction will allow a bit of brightness control.
-Anthony
-Anthony
- aeiou
You can also use Ram's device:
http://www2.towerhobbies.com/cgi-bin/wti0001p?&I=LXDZ89&P=7
http://www.ramrcandramtrack.com/rcpower.html
Works for lights and sound...
- 1284 Views
Last post by mrfoski
- 1062 Views
Last post by Mad Racer
- 1135 Views
Last post by vwjuice
- 599 Views
- 600 Views
Last post by tamiyadan
- 26 Replies
- 2912 Views
Last post by Orange
- 1294 Views
Last post by Typicray@rainmans
- 1803 Views
Last post by Saito
