I am looking for a small set of shocks for a random project, and am thinking that Micro T shocks look about the right size. Does anyone have one that they can give me a measurement on?
I'm looking for:
1. overall length (eye to eye) - shooting for around 50mm
2. overall diameter - looking to be as close to 10-12mm as possible
Also, any other suggestions for shocks about that size would be great - the diameter is the killer. I could go a bit bigger, but probably not much more that 15mm without major issues.
Thanks!
Need dimensions for Micro T Shocks
- Been thanked: 12 times
Re: Need dimensions for Micro T Shocks
my micro-t front shocks measure 26mm eye-eye diameter is about 5mm except for the top of the shock where the screw holds the cap on, that portion is 7mm
rear shocks are the same except for length is about 31mm
the shocks from a losi mini latemodel might work. The threaded aluminum shocks measure about 50mm long and 12mm diameter at the spring collar. mine might have a small limiter inside to get them to the 50mm length, I don't recall how I built them.
http://losi.com/Products/Features.aspx?ProdId=LOSB1289
- 485 Views
Last post by BattleTrak
- 1191 Views
Last post by jfharper
- 1400 Views
Last post by limestang
- 511 Views
Last post by treehugger
- 25 Replies
- 2147 Views
Last post by Ron Jeremy
- 869 Views
Last post by markbt73
- 453 Views
- 524 Views
Last post by Pyxster
