need help with Composite Craft worlds car build
Post Reply
asashaw
Post by asashaw »
Hey guys, just wanted some opinions with what you have done to the rear bulkhead to make it fit with the a-arms. Also I am running into some clearance problems with the upper deck hitting the rear shock tower... what did you guys do? Any suggestions would be great. here are my pics... I think the rear bulkhead looks ugly now.
thanks
asa
shodog
Been thanked: 86 times
Post by shodog »
you have to trim the bulkhead back pretty far just like you did. As for the rear shock tower, you need to shave a tiny bit off the bottom of it so it will clear the top plate.
Asso_man!
Has thanked: 40 times
Been thanked: 70 times
Post by Asso_man! »
use some sandpaper to clear the rear shock tower on a flat surface :wink:
Come and visit the stable
Has thanked: 28 times
Been thanked: 957 times
you didn't need to trim so much off the sides of the battery area. now if you did want to use the car, there's not much there to hold the battery pack in the back. if at all.
asashaw
your parts
Post by asashaw »
can i see pictures of what you guys have done?
thanks
asa :D
badhoopty
Has thanked: 15 times
Been thanked: 35 times
Post by badhoopty »
i've never used a rpm bulkhead with the worlds car composite craft, but a stocker bulkhead only needs to be clearanced about 1/4".
for the tower making contact with the plate, just cut about an 1/8" strip off the bottom of the tower.
here's mine....................
shodog
Post by shodog »
I don't have a really good shot of just the bulkhead. This one shows that I cut it similar to scr8p's
I also cut the top to follow the cut out of the top plate
badhoopty
Post by badhoopty »
couple different examples. all black rig shows stock tower and just clearancing the area under the upper deck screws, keeping the gap overall nice and tasty (imho). second pic shows how little of the stock bulk really needs to be trimmed.
Post Reply
  • Composite Craft Worlds Car build
    by transamman908 » » in RC10 Buggy Forum
    Last post by wyldbill
  • Composite Craft Worlds build
    by fastang » » in RC10 Buggy Forum
  • RC10 Composite Craft Worlds build
    by Lavigna » » in RC10 Buggy Forum
    Last post by MarkyDents
  • RC10 Composite Craft Worlds build #2
    Last post by Lavigna
  • '91 Composite Craft/RPM Worlds build
    by vsefiream » » in RC10 Buggy Forum
    Last post by Peakey
  • Composite Craft RPM '91 Worlds build thread
    by jcwrks » » in RC10 Buggy Forum
    Last post by jcwrks
  • Composite Craft Worlds Car Graphite Chassis set
    by transamman908 » » in Temple's RC10 Tech Forum
  • Factory Works Composite Craft Worlds Cheater RC10T build
    by Lavigna » » in RC10 Truck Forum
Users browsing this forum: No User AvatarAhrefs [Bot] and 53 guests
