I know there are holes in the list, but we can continue to build on this as we go. It's fairly comprehensive thus far, so hopefully this can help those of you who are looking for the general information on these motors. Feel free to offer corrections or other part numbers with corresponding motor specs prior to the year 2000, and I will update the list!
If you reference any of this info on other sites, please link to us as the source.
Aristo-Craft
Power Plus
700V
The top choice for 8-minute racing In 1/12 scale road-racing cars.
Highest top speed. Excellent acceleration.
Quadruple windings for unsurpassed conductor cross-sectional area and power.
704B
Designed for off-road buggies with a longer armature and field poles for higher torque.
Timing pre-set for maximum torque.
800G
Optimized for long (up to 8 minute) races in lightweight cars (under 900g)
to give maximum top speed with good acceleration.
804Y
Optimized for off-road racing and where high performance in the rough is needed.
Longer rotor and field poles for higher torque than 540 size motors.
Designed to deliver the power without overheating under heavy loads.
900O
Optimized for 4-minute sprint races in which both maximum acceleration and maximum top speed are needed.
2614BE
The top choice for off-road 1/10 scale buggy racing and power in the rough.
The best choice for rear-motor 2-wheel drive types.
Double windings for large conductor cross-section.
2616R
The top choice for 8-minute sprint races in 1/12 scale road-racing cars where all-out maximum speed and acceleration are required.
Astro Flight
Marine
304 4T #18 Cobalt 05 300W 24,000 RPM Prop X4-32
306 4T #18 Cobalt 05 400W 24,000 RPM Prop X4-35
326 4T #17 Cobalt 25 600W 21,000 RPM Prop X4-45
341 4T #17 Cobalt 40 800W 21,000 RPM Prop X4-50
Pulling
505 10T #21 Pullmaster I 32,000 RPM
507 8T #20 Pullmaster III 26,150 RPM
508 6T #19 Pullmaster IV 29,800 RPM
Full Specs
Drag
509 5T Top Fuel I (Alternative)
510 6T #19 Top Fuel I 50,000 RPM
511 6T #19 Top Fuel II 60,000 RPM
512 5T Top Fuel II (Alternative)
Full Specs
Race
514 5T #18 Pro Stock 48,000 RPM
515 6T #19 Turbo-05 26,700 RPM
Full Specs
B&R Motorworks
1010 22 Magnum ROAR 91 Stock
1012 ROAR Stock (Silver Can With Yellow, Orange, Pink Sportsman Label)
1013 ROAR 91 Stock Buckshot 24° Black/Chrome Epic
1015 27x1 AYK Off Road ROAR Stock (Silver Can With Orange Endbell And Pink, Purple, Blue MotorWorks Label)
1018 27x1 Yokomo Dyno ROAR Stock
1022 27x1 Bullet Stock (Silver Can With Pink, Purple, Blue Bullet Label)
1022-P 27x1 Bullet Pro Stock (Silver Can With Pink, Purple, Blue Bullet Pro Label)
1025 27x1 Magnum Stock
1030 44 Magnum Outlaw Stock
1031 Pro-Stock Signature 34°
2111 11x1 Yokomo Drag/Oval
2113 13x1 Yokomo Oval
2114 14x1 Yokomo On Road/Oval Motor Works
2115 15x1 Yokomo Off Road
2116 16x1 Yokomo On Road/Oval
2117 17x1 Yokomo Off Road
2118 18x1 Yokomo Off Road
2211 11x2 Yokomo Drag/Oval
2212 12x2 Yokomo Oval
2213 13x2 Yokomo Oval
2214 14x2 Yokomo On Road/Oval
2215 15x2 Yokomo On Road
2216 16x2 Yokomo Off Road
2221 21x1 Yokomo Off Road
2312 12x3 Yokomo Oval
2313 13x3 Yokomo Oval
2314 14x3 Yokomo Oval
2315 15x3 Yokomo Oval
2316 16x3 Yokomo Off Road
2318 18x3 Yokomo Off Road
2319 19x3 Yokomo Off Road/On Road
2412 12x4 Yokomo Off Road/Oval
2414 14x4 Yokomo Off Road/Oval
2415 15x4 Yokomo Off Road/On Road
2417 17x4 Yokomo Off Road
2513 13x5 Yokomo
3014 14X2 Sportsman 3000
3015 15X2 Sportsman 3000
3017 17x1 Sportsman 3000
3018 18x2 Sportsman 3000
3020 20x1 Sportsman 3000
3023 23x1 Sportsman 3000
3213 13X2 Sportsman 3200
3215 15X2 Sportsman 3200
3217 17X2 Sportsman 3200
3219 19X2 Sportsman 3200
Badd Boyz
BBZ9132 13x2
Big Jim (Greenemeyer) Racing
Stock Class
1210 36° Short Stack "Pinkie"
1220 24° ROAR 91 Spec.
1225 24° ROAR 91 Truck "Green Meanie" (Green Can With Black & Silver Label)
1230 24° Monster Truck
Black Magic
Voodoo Graveyard Stock
V15 15° 15x2
V18 15° 18x2
1000 30° ROAR Stock Legal
1012 12x1 51,000 RPM
1013 13x1 48,000 RPM
1014 14x1 44,000 RPM
2010 10x2 54,700 RPM
2011 11x2 49,200 RPM
2012 12x2 48,400 RPM
2013 13x2 47,100 RPM
2014 14x2 44,300 RPM
2015 15x2 41,700 RPM
3014 14x3 47,600 RPM
3017 17x3 38,000 RPM
3020 20x3 31,000 RPM
4013 13x4 48,100 RPM
4014 14x4 47,250 RPM
4016 16x4 40,200 RPM
4018 18x4 38,800 RPM
Drag
5001 8 Cell
5002 10 Cell
5003 14-20 Cell Voodoo
5004 8 Cell Pro Stock
5005 T/F Cauldron Fire
6004 16 Cell Cobalt (German Case)
Marine
6001 Double 44,000 RPM
6002 Triple 48,000 RPM
6003 12 Cell 52,000 RPM
6005 24 Cell Cobalt (German Case)
Truck
7001 Super High-Torque (World Champion)
7002 Dual Motor Hi-Speed Pair
7003 Dual Motor High-Torque (Clod Buster)
7005 550 Stock Pulling (World Champion)
7006 750 Open 1 Pulling
6004 16 Cell Cobalt (German Case) (World Champion)
6005 24 Cell Cobalt (German Case) (World Champion)
BoLink
BL-4000 Hand Selected - Balanced & Epoxied - ROAR Legal D-Production
BL-4002 "Yellowjacket" Double Wind Custom Hand Wound In USA
BL-4003 "Wasp" 22 GA Wire (Machine) Import
BL-4004 "Hornet" Double Wound Balanced & Epoxied B/B Can & Endbell
BL-4007 "Stinger" Hot Modified Off Road Competition Motor With (BL-4229) Modular Endbell
BL-4010 ROAR Legal Yokomo Stock Motor With 12° Timing. More Bottom-End Torque For Short, Tight Tracks.
BL-4014 "Stage IV" High Performance Motor (Black Can With Silver Label)
BL-4020 ROAR Legal Yokomo Stock Motor With 18° Timing.
BL-4024 1/10th Scale Modified Motor For Oval Racing. Lots Of Top-End For Wide Open Tracks.
BL-4025 1/10th Scale Modified Motor For Road Course Racing. More Low-End And Mid-Range Power For Extra Punch Coming Out Of The Turns.
Bud's Racing Products
7205 ROAR 91 Legal Stock
CAM Pro-Motors
1/12 and 1/10 Stock
0999 27x1 Yokomo Pro Stock
1/10 Drag
1000 12x2
1001 10x2
1/10 Off Road
1020 19x2
1021 19x1
1022 17x1
1023 16x3
1024 16x2
1/10 Oval
1040 15x2
1041 15x1
1042 14x2
1043 14x1
1044 13x3
1045 13x2
1046 15x3
1050 12x2
1/10 On Road
1060 15x1
1061 15x2
1062 17x1
1063 17x2
1/12 On Road
1070 20x2
1071 17x2
1/12 (4 Cell)
1080 17x1
1081 16x1
1082 16x4
1083 15x2
1065 15x1
1067 15x2
CAM0999S 36x2 Stock Pink Outlaw (Pink Can & Endbell With Blue Label Text)
Duratrax PowerLine
DTXC3110 18x1 Monster Truck High Torque 30,000 RPM
DTXC3120 17x3 2wd Off Road 45,000 RPM
DTXC3130 13x2 4wd Off Road/Dirt Oval 49,000 RPM
DTXC3140 12x3 Oval On Road/High Speed Dirt Oval 50,000 RPM
DTXC3200 27T 24° Slot Mania Stock 91 ROAR Legal High Speed On/Off Road 25,100 RPM
DTXC3210 27T 36° Outlaw Stock NORRCA Legal Short Stack On/Off Road 25,200 RPM
Dymond (UMP/UMD - United Model Products/Distributors)
RED Label
2 Ball Bearings
Double Wound With .022 Gauge Wire
Epoxy Coated Winding
Positive Lock Ferrite Magnets "A"
Hard Brushes
1 16x2 Oval 30,000 RPM
2 17x2 Super Sprint 28,000 RPM
3 18x2 Sprint 26,900 RPM
4 19x2 Enduro 26,000 RPM
5 20x2 Eco 24,800 RPM
SILVER Label
2 Ball Bearings
Positive Lock Ferrite Magnets "B"
Extra Hard Brushes
6 16x2 Oval 29,200 RPM
7 17x2 Super Sprint 26,900 RPM
8 18x2 Sprint 26,000 RPM
GREEN Label
2 Ball Bearings
Triple Wound With .0185 Gauge Wire
Medium Hard Brushes
9 20x3 Super Sprint 24,500 RPM
10 21x3 Sprint 23,900 RPM
11 22x3 Enduro 22,700 RPM
12 23x3 Eco 21,700 RPM
BLACK Label
2 Plain Bearings
Medium Hard Brushes
13 20x2 Super Sprint 24,8000 RPM
14 21x2 Sprint 24,100 RPM
GOLD Label
900 14x2 2 Wheel Drive Oval (Very Hot Super Strong Mid-Range And Top End) 40,000 RPM
901 15x2 4 Wheel Drive Oval (More Torque Than 2 Wheel Drive Oval) 38,000 RPM
902 17x3 2 Wheel Drive Off Road (Smooth Power Band) 33,000 RPM
903 16x2 4 Wheel Drive Off Road (Excellent Torque) 31,000 RPM
904 13x2 1/10 On Road (Blazing Top Speed) 44,000 RPM
905 20x3 1/10 Road Course (Very Strong Off Corners With Excellent Mid-Range) 30,000 RPM
906 1/12 4 Cell 8 Minute (Special Wind Built For 1700mAh Batteries) 30,000 RPM
East Coast
2704 38° (Wet Mag) Viper Stock
1204 12x4 ECR Handwound Modified
Elite Speed Products (ESP)
EL901 24x2 SLII EX Stock R91 (Yellow Label With Orange Endbell)
EL902 24x2 5.0 Mag Stock (Green Can & Endbell With Yellow Label)
EL903 36x2 4.95 Mag Stock (Pink Can & Endbell With Yellow Label)
EL960 24° Stock Lightning (White Label With Stars & Prismatic Text)
EL970 24° Stock Sorcerer (Black Can With Yellow Label & Blue & Red Text)
Endurance Racing Products (ERP)
ERP 2400 24° Stock 1991 Jackpot (Upgraded 7001 Brushes / Zapped Race Ready)
ESP (Clodzilla)
ESP042 14x2 Power-Up
Extreme Motorsports
2420 24° The Obliterator (Megatonic Tech Stuffed Into A ROAR Legal Package)
2480 The Smoke Part II!!!! (Green Can Orange Label)
4020 36° The Megatonic (Short Stack Hand-Tuned By "Doc" Erik Soderquist Pink Epic-Based Motor)
4040 36° Bruno Max (Obliterator's Full-Stack Big Brother)
4060 The Megatonic Part II!!!! (Epic 5.0 Pink Can Stamped NORRCA On Bottom)
Gonzo/Wimpy
Modified
WIM10D 10x2
WIM11T 11x3
WIM12D 12x2
WIM12T 12x3
WIM13D 13x2
WIM13T 13x3
WIM14S 14x1
WIM14D 14x2
WIM14T 14x3
WIM14Q 14x4
WIM15D 15x2
WIM15T 15x3
WIM15Q 15x4
WIM16T 16x3
WIM17T 17x3
WIM18D 18x2
Stock
WIM200 Wimpy "X"
WIM200-D Wimpy "X" Dyno Stock
HPI
Modified
1112 12x2 Bushing
UNO
1010 15x2 10° Sports (Steel Bushings And 4.9 High-Torque Wet Magnets)
1015 18x2 10° Sports (Steel Bushings And 4.9 High-Torque Wet Magnets)
1030 14x2 Club Racer (Mint Green Label With White, Yellow, Pink, Lettering)
1035 18x2 M-Truck Club Racer
1042 GTR 2 Modified Motor (Black And Chrome Label With Pink Number 2)
1200 24° Stock M-Truck Club Racer (Includes A Pair Of Push-In-Type Tamiya Connectors And Capacitors)
H1004 Off-Road Motor (Blue Label With Red Triangle And White Lettering - '87 World Champion)
S1201-1 Off-Road Motor (Blue Label With Red Triangle And White Lettering - '87 World Champion)
S1202 1/12 On-Road Motor (Blue Label With Red Triangle And White Lettering - '87 World Champion)
Keystone
240 Wild Thing ROAR 91 Stock - High Torque Short Track
Kose
K-315D 15x2 MadMax EX Competition
K-317D 17x2 MadMax EX Competition
K-318S 18x3 MadMax EX Competition
Kyosho
Le Mans Motors
1891 480S 24T 22,000 RPM
1893 240S 19T 25,000 RPM
1894 600E 30T 18,500 RPM
1895 360PT 19T (550 Size) 21,000 RPM
1897 480 Gold 25T 22,000 RPM
1898 360ST 22T (550 Size)
1924 240SB 19T 30,000 RPM
1925 360 Gold 18T (550 Size) 23,000 RPM
1926 Sports H-240S 20T
1986 Speed 240T 16T 28,500 RPM
1988 Speed 480T 19T 26,500 RPM
2483 Pro High Torque 16T 30,000 RPM
W1011 SPA 240WS 18T 31,000 RPM
W1012 SPA 480WT 24T 23,000 RPM
KYOG1984 30T 600E Off Road 18,000 RPM
KYOG1922 27x1 Stock 05 Off Road 18,000 RPM
KYOG1929 29T AP29 Small Planes/Boats 18,000 RPM
KYOG1929 30x1 AP-29 Small Planes/Boats 16,000 RPM (Alternative?)
KYOG1930 27x1 AP-29BB Small Planes/Boats 20,000 RPM
KYOG1961 29T AP29R Reverse Rotation For Geared Planes/Boats 18,000 RPM
KYOG1934 50x1 DM20 Mini Motor For Small Electrics 24,800 RPM
KYOG1935 50x1 DMC20BB Cone Bearing Mini Motor For Small Electrics 25,500 RPM
KYOG1962 22T or 18x2 AP36 High Speed For Electric Planes 21,600 RPM
KYOG2461 19x2 AP36L Special Planes/Boats 28,000 RPM
Mad Science Motor Series (K-Speed)
ROAR Legal Stock
70511 27x1 24° Ion Storm
Modified
70561 11x2 Terminal Velocity 4wd Buggy/On Road
70562 12x2 Atom Smasher On Road
70564 14x2 Krypton Krystal 2wd Trucks/Buggy/Touring Car
70566 16x2 EndoPlasma 2wd Trucks/Buggy/Touring Car
70567 17x2 Atomic Force Trucks/Planes/Boats
Monster Truck
70671 (KYOG2710) 22x1 550 Can Magnetic Mayhem
70672 (KYOG2711) 22x1 550 Can Magnetic Mayhem (Reverse Rotation)
XSpeed
70901-10T 10x3 Modified
70901-11T 11x3 Modified
70901-12T 12x3 Modified
70901-15T 15x3 Modified
70902-12W 12x2 Stock
70902-14W 14x2 Stock
70902-15W 15x2 Stock
70902-16W 16x2 Stock
70902-18W 18x2 Stock
Competition Series Super Stock Motors
KYOG2000 (Alt P/N 1992) Super Stock 20 - 27T 20° Off Road 21,600 RPM
KYOG2010 (Alt P/N 1993) Super Stock 34 - 27T 34° Off Road 28,000 RPM
KYOG2024 27T 24° ROAR '91 Stock Off Road 28,000 RPM
KYOG2030 Sport Racing Stock Motor (Yellow Red Blue Can)
Speed Stock Motors
KYOG2153 13T K-Speed
KYOG2154 15T K-Speed
KYOG2155 17T K-Speed
KYOG2156 19T K-Speed
KYOG2157 21T K-Speed
KYOG2158 23T K-Speed
Mega Motors
KYOG2471 12x2 Paved Oval - Dirt Oval/4wd Off Road 37,000 RPM
KYOG2472 14x2 Dirt Oval - Paved Oval/4wd Off Road 33,000 RPM
KYOG2473 16x2 4wd Off Road - 2wd/4wd Off Road/Dirt Oval 29,000 RPM
KYOG2474 18x2 2wd Off Road - 2wd/4wd Off Road/1/10 On Road 27,000 RPM
KYOG2475 20x2 On Road - 1/10 1/12 24,000 RPM
KYOG2476 22x1 Outlaw Stock - 1/10 1/12 22,000 RPM
KYOG2477 360 Monster Truck - Dual Motor Trucks 21,000 RPM
KYOG2479 360 Monster Reverse - Dual Motor Trucks 21,000 RPM
Leisure
1002 "05" Roar Legal - Stock
1002A Off Road Stock (ORRCA Legal) Bushing
1002A "05" Modified Red Label
1002B "05" Modified Black Label
1002BX 3 Cell Modified (1/12 Scale) Ball Bearing
1002BX Off Road Modified (36mm Dia.)
1002E 7 Cell Modified (Off Road) Ball Bearing
1002M6 6 Volt Boat Motor Ball Bearing
1002M12 12 Volt Boat Motor Ball Bearing
LT-50 Modular Electric Motor
Competition Wind 5-7 Minutes
6x4 (Cox Grey) 13,300 RPM
7x4 (Rev-Up) 12,400 RPM
8x4 (Rev-Up) 11,000 RPM
Pattern Wind 10 Minutes
6x4 (Cox Grey) 13,000 RPM
7x4 (Rev-Up) 12,000 RPM
8x4 (Rev-Up) 10,500 RPM
Lightspeed Products
Spirit 24° Competition Stock
LRP
5713 13x2 F1
5715 15x2 F1
5717 17x2 F1
5718 18x4 DTM Special
5723 23x2 F1
5725 (Double) 25x2? VX Turbo
5736 Truck Puller
5817 17x2 Rallye
5819 19x2 Rallye
5821 21x2 Rallye
5823 23x2 Rallye
5825 VB Superprop
5826 23T Runner 2
Magnum Motor Works
MAGK133 13x3
Maxtec
MS011 TEAM Black Knight 24° Stock ROAR & NORRCA Legal (Black Can & Label)
MS016 TEAM Pink Part III 30° Pink Stock NORRCA Legal (Pink Can)
MC2 Nexxus
NX5250 Nexxus 27T 24° ROAR Stock (Red Can)
X57250 X5 27T 24° ROAR Stock (Blue Can)
STR6250 Street Fighter 27T 24° 91 ROAR Stock
Motor Man
MMSMSPEED 24° Speed Master ROAR Legal Stock Motor Oval / Long Straights Slotted Armature
MM1003 24° Stock Master 1.3mm Thick Motor Can 5.2 Wet Magnets Silver H-Cut Brushes
MM2XXX Pro Series Modified Motors Epic Based 5.1 Magnets Available In A Variety Of Winds.
MM10XX Big Bore Motors Custom Wound Modified Laydown Yokomo Can Hand Wound Armature Available In Popular Winds.
MM15D 15X2 Hurricane
MM19D 19X2 Tornado
MM1110 10X3 Monsoon
MM1114 14X3 Monsoon Machine Wound Bushing Equipped Modified Legal For Tamiya Champion Series Races.
MM1115 14X4 Hurricane
MM1116 16X3 Typhoon
MM1117 17X1 Tornado
MM1127 27X1 36° Short Stuff Stock
MRP
Pro-Trix
95-554 20T Modified Motor Custom Wind - Silver Label Red Checkers
95-555 Modified Motor Oval/Sprint 8.4v - Silver Label Yellow Checkers
95-0552 Motor GP .05 Factory Tweaked ROAR Stock - Silver Label Green Checkers
Wizzard
10-2801 Marine Series - 1 (MS-1) 8.4-14.4 Volts - Replacement For: Outboard Tunnel Hulls, Outrageous K-Class, Gentry Eagle, Skater Outboard
10-2802 Marine Series - 2 (MS-2) 7.2-12 Volts - Replacement For: Miss Budweiser Hydro, Mr. Pringle's Hydro, Circus Circus Hydro, Americana
10-2803 Marine Series - 3 (MS-3) 6-7.2 Volts - Replacement For: Hydro Sport, Vee Sport, Fast-Cat, Viper Canard, Italia
Nikko
CP-002E Up Works 240SWM Cobra
Up Works 240SWM Cheetah
Up Works 240SWS Cobra
Up Works 240SWS Cheetah
Up Works 480SWM
UP 240SWM Cobra
UP 240SWM Cheetah
UP 240SWS Cobra
UP 240SWS Cheetah
UP 480SWM
UP 240SE
240B
240BB
Paragon
Eclipse Series
ECO17 17T
ECO20 20T
ECO23 23T
ECO13 13T
ECO15 15T
ECO19 19T
Modified Motors
1/10 On Road
10142 14T
10152 15T
10162 16T
10172 17T
10182 18T
1/12 (4 Cell)
12154 15T
12164 16T
12172 17T
12182 18T
1/12 (6 Cell)
12192 19T
12202 20T
12212 21T
12222 22T
1/10 Off Road - 2wd
20182 18T
20192 19T
20202 20T
20212 21T
1/10 Off Road - 4wd
40133 13T
40142 14T
40152 15T
40162 16T
40172 17T
40182 18T
1/10 Oval
50122 12T
50133 13T
50143 14T
50152 15T
50162 16T
Drag
60092 9T
60102 10T
60112 11T
1/10 Truck
70172 17T
70184 18T
70194 19T
Pro Stock Motor
10000 27T 24° ROAR Legal
EC014 14x2 Eclipse Tamiya Legal
Parma
01 19x4 Yokomo
02 19x4 Kyosho
03 19x4 Cyclone
04 23x2 Yokomo
05 23x2 Kyosho
06 24x2 Cyclone
07 24x2 Yokomo
08 24x2 Kyosho
09 24x2 Cyclone
10 19x2 Yokomo
11 19x2 Kyosho
12 19x2 Cyclone
13 20x2 Yokomo
14 20x2 Kyosho
15 20x- Cyclone
16 15x4 Yokomo
17 15x4 Kyosho
18 15x4 Cyclone
19 17x4 Yokomo
20 17x4 Kyosho
21 17x4 Cyclone
22 28x1 Yokomo
23 27x1 Kyosho
24 27x1 Cyclone
25 16x2 Cyclone
26 19x1 Cyclone
27 18x- Cyclone
28 15x2 Cyclone
1/12 Lotus Motor
2106 29 Turns Of 23 Gauge
2108 32 Turns Of 23 Gauge
1/12 Ferrari Motor
3046 6 Cell 6 Minutes
3048 4 Cell 8 Minutes
Turbo Porsche Motor
3012 32T Of 22 Gauge
1988 Specifications
14001/2/3 19x4 Yokomo/K-Motor/Cyclone 31,700 RPM
14004/5/6 23x2 Yokomo/K-Motor/Cyclone 29,250 RPM
14007/8/9 24x2 Yokomo/K-Motor/Cyclone 28,750 RPM
14010/11/12 19x2 Yokomo/K-Motor/Cyclone 30,000 RPM
14013/14/15 20x2 Yokomo/K-Motor/Cyclone 32,750 RPM
14016/17/18 15x4 Yokomo/K-Motor/Cyclone 33,250 RPM
14019/20/21 17x4 Yokomo/K-Motor/Cyclone 32,250 RPM
14022 28x1 Yokomo Stock 27,000 RPM
14023 27x1 K-Stock 27,000 RPM
14024 27x1 Cyclone Stock 27,000 RPM
14025 16x2 Cyclone 33,000 RPM
14026 19x1 Cyclone 31,500 RPM
14027 18x1 Cyclone 31,000 RPM
14028 15x2 Cyclone 35,000 RPM
Cyclone II Series
14100 27x1 6° ROAR Stock Dry Magnets No Comm Lock (Blue Decal Lettering)
14101 27x1 24° ROAR Stock Wet Magnets With Comm Lock
14103 27x1 40° 'Stock Plus' Outlaw Stock Wet Magnets
14150 25x1 Super Stock - All Tracks (Green Decal Lettering)
14200 17x1 Ultra Stock - All Tracks (Pinkish Red Decal Lettering)
14250 18x2 Pro Modified - Medium Dirt Tracks (Orange Decal Lettering)
14251 16x2 Pro Modified - Dirt Tracks (Orange Decal Lettering)
14300 17x2 Super Modified - Medium Dirt Tracks (Yellow Decal Lettering)
14301 15T Super Modified - Medium Dirt Tracks (Yellow Decal Lettering)
14302 13x2 Super Modified - All Size Dirt Tracks (Yellow Decal Lettering)
14350 21x2 T.Q. Modified - Short Tracks (Pink Decal Lettering)
14351 20x3 T.Q. Modified - Asphalt (Pink Decal Lettering)
14352 19x4 T.Q. Modified - Carpet (Pink Decal Lettering)
14353 17x3 T.Q. Modified - Flat Tracks (Pink Decal Lettering)
14354 16x1 T.Q. Modified - Short Tracks (Pink Decal Lettering)
14355 14x2 T.Q. Modified - All Tracks (Pink Decal Lettering)
14356 12x3 T.Q. Modified - Long Oval Tracks (Pink Decal Lettering)
14357 13x1 T.Q. Modified - 4 Wheel Drive (Pink Decal Lettering)
14358 8x1 T.Q. Modified - Drag (Pink Decal Lettering)
14359 30x1 T.Q. Modified - Trucks/Pullers (Pink Decal Lettering)
14367 15x3 Road-Runner
90002 13x4 Hand Wound Modified
Peak Performance
P10 27x1 Yokomo Stock Motor
P15 22x2 6-Cell
P20 20x2 2wd Off Road
P27 21x2 Monster Truck
P30 18x2 4wd Off Road
P35 17x2 Sprint
P40 16x2 Dirt Oval
P45 16x4 Animal
P50 14x2 Super Oval
P55 14x2 Wild Thing
P60 12x2 Beast
P80 17x2 Short Road Course
P81 16x2 Long Road Course
P85 15x2 Short Track Oval
P90 13x3 Rick's Pick
P99 13x2 Hi Torque
PP08 Demon Stock 38° Hyper Stock (Silver Can With Sky Blue Label)
PP09 Dragon Stock Roar '91 27 Turn High Performance Stock (Silver Can With Sky Blue Label And Red Endbell)
PP10 Off Road Stock (Silver Can With Yellow Label)
PP11 Macho Stock 24° Wet Magnets Heat Sink Endbell Racing Brushes
PP12 Son Of Psycho Stock 36° Slotted Short-Stack Armature Soft Racing Brushes (Pink Can With Yellow Label)
PP13 Psycho Stock With Competition Brushes (Silver Can With Orange Label)
PP13 Psycho III Stock 36° (Pink Can With Yellow Label)
PP15 Gator II Stock Roar '91 24° Unique "Tri-Rotor" Armature, With Grooved, Lighter "Uni-Flow" Endbell (Green Epic Can With Yellow Or Sky Blue Label)
PP15R Beast Stock Roar '91 24° Unique "Tri-Rotor" Armature, With Grooved, Lighter "Uni-Flow" Endbell (Green Epic Can With Black Label)
PP25 19x4 Monster Truck (Black Can With Yellow Label)
PP84 15x2 Off-Road Modified (Black Can With Yellow Label)
PP108 15x2 DT Touring Car Dyno-Tuned - Yokomo Esprit - Bushing - NORRCA Legal Modified (Silver Can With Black And Gold Label)
Point Blank (Not Trinity)
P300 ROAR 91 Slotted Stock
P301 ROAR 91 Short Slotted Stock
P302 NORRCA 92 Short Stock
P303 15T Outlaw Stock
P304 8T Rare Earth Drag Or Pulling Modified Motor
P305 9T Rare Earth Drag Or Pulling Modified Motor
P306 10T Rare Earth Drag Or Pulling Modified Motor
Quarter Flash
101 10x1 Drag
103 12x2 Drag
151 15X2 Quick Silver Pro Modified
152 19X2 Quick Silver Pro Modified
153 13x2 Quick Silver Pro Modified
201 30° Wet Magnet Pre-Tweaked Stock
202 17X1 Quick Silver Pro Stock
203 20X1 Quick Silver Pro Stock
211 24°Slot 91 Thunderbolt
213 Big D's Express 36° Outlaw Stock Slotted Short-Stack Armature 4.9 Wet Magnets Heat Sink Endbell 401 Ultra Silver Brushes CEI Turbodyno Tested Off Road/Oval (Fluorescent-Pink Can)
Race Prep
903A 27x1 Dynopower Stock
903Z 27x1 "Zapped" Dyno Stock
90512D 12x2 Pro Series
90513D 13x2 Pro Series
90514D 14x2 Pro Series
90515D 15x2 Pro Series
90516D 16x2 Pro Series
90517D 17x2 Pro Series
90518D 18x2 Pro Series
90519D 19x2 Pro Series
90521D 21x2 Pro Series
90514S 14x1 Pro Series
90515S 15x1 Pro Series
90516S 16x1 Pro Series
90517S 17x1 Pro Series
90518S 18x1 Pro Series
90520S 20x1 Pro Series
RP-24 24° Airtime ROAR '91/NORRCA Legal Stock Mike Dunn Developed NSR (Narrow Split Rotor) Armature 4.95 Wet Magnets Silver "R" And Stage 2 FTC (Fine-Tune Concept) Brushes CEI Turbodyno Tested
RP-38 38° 38 Special NORRCA/ROAR '90 Specifications NSR (Narrow Split Rotor) Armature Stage 2 FTC (Fine-Tune Concept) Brushes CEI Turbodyno Tested
RP-242 24° "Purple Haze" Power Zone ROAR '91/NORRCA Legal Stock
RP-244 24° "Hack Attack" ROAR '91/NORRCA Legal Stock
Racetech
Modifieds
1020 10x2 Velocity
1220 12x2 Velocity
1230 12x3 Velocity
1620 16x2 Velocity
0500BW Black Widow Stock
Red Line
Modifieds
6501 21 Wind 2WD
6502 19 Wind 2WD
6503 17 Wind 2, 4WD
Reedy
Stock Motors
300 27T Fire Hawk 24° ROAR Stock
301 27T Fire Hawk Plus 24° ROAR Stock #767 Brushes (Includes Dyno Printout)
302 27T Conquest 36° Stock
303 27T Conquest Plus 36° Stock #767 Brushes (Includes Dyno Printout)
304 Rage 24 24° ROAR Stock #767 Brushes 3HL Dual Rotor Arm
305 Rage Plus 24° ROAR Stock #769 Brushes 3HL Dual Rotor Arm (Includes Dyno Printout)
306 Rage Type R 24° Rebuildable ROAR Stock #767 Brushes 3HL Dual Rotor Arm
307 Rage Type R Plus 24° Rebuildable ROAR Stock #769 Brushes 3HL Dual Rotor Arm (Includes Dyno Printout)
Tri-Sonic Series
310 12x2 “S” On Road
311 12x5 “I” On Road
312 13x2 “M” On Road
313 13x3 “C” On Road
314 14x4 “D” On Road
315 15x3 “B” On Road
316 16x5 “V” On Road
317 11x2 “0”
318 13x5 “P”
319 14x5 “A”
320 15x5 “B”
321 10x4 “X”
323 10x2 “?”
324 10x3 “Y”
326 9x3 “93”
328 11x3 “T”
329 9x5 “95”
Sonic 2 Series
350 12x2 “S”
351 11x2 “O”
352 10x2 “?”
354 11x3 “T”
355 10x4 “X”
356 11x5 “W”
357 12x4 “J”
358 13x2 “M”
360 13x5
361 12x5
363 10x5
364 9x2 “92”
365 9x5
Fury - Millennium Wind
416 12x3 MW
417 11x3 MW
418 10x3 MW
419 9x3 MW
421 12x3 MW (Triple Armature)
422 13x3 MW (Triple Armature)
Conquest Modifieds
490 17 Turn Bushing
491 15 Turn Bushing
492 14 Turn Bushing
495 15 Turn Machine Wound Bearing
496 17 Turn Machine Wound Bearing
497 14 Turn Machine Wound Bearing
Pulse-R
501 14x2
502 13x2
503 12x2
504 11x2
505 10x2
506 9x2
MR. Series
501 17x4 Mr. K's
502 16x3 Mr. R's
503 14x4 Mr. D's
504 13x4 Mr. C's
505 12x4 Mr. J's
506 13x3 Mr. E's
507 12x3 Mr. H's
508 14x3 Mr. A's
509 14x2 Mr. L's
510 11x3 Mr. T's
511 19x3 Mr. N's
512 13x2 Mr. M's
513 15x4 Mr. F's
514 15x3 Mr. B's
515 10x4 Mr. X's
516 12x2 Mr. S's
517 11x2 Mr. O's
518 11x4 Mr. G's
519 10x3 Mr. Y's
520 10x2 Mr. ?'s
521 16x2 Mr. Z's
522 12x1 Mr. !'s
523 15x2 Mr. Q's
524 12X2 Mr. BK's
000 10X4 Mr. I's
000 16X4 Mr. V's
000 11X3 Mr. W's
Sonic Series (Large Comm)
525 14x3 “A”
526 15x3 “B"
527 13x4 “C”
528 14x4 “D”
529 13x3 “E”
530 15x4 “F”
531 11x4 “G”
532 12x4 “J”
533 14x2 “L”
534 13x2 “M”
535 11x2 “0”
538 12x2 “S”
539 10x2 “?”
541 11x3 “T”
542 10x3 “Y”
544 12x5 “I”
545 11x5 “W”
546 10x5 “U”
547 10x4 “X”
548 17x4 “K”
TC1 - Touring Car Modified
550 14T (5-Minute)
551 13T (5-Minute)
552 12T (5-Minute)
553 11T (4-Minute High Torque Or 5-Minute Standard)
554 10T (4-Minute)
555 9T (4-Minute High RPM)
551 27T Mr. Outlaw Stock 36° or 38° NORRCA Legal
552 Super TRU Stock 22°To 24° Super Outlaw Spec But With Comm Locking Device ROAR Approved
553 27T Super Outlaw 38° Stock Wet Magnets On Road And 2wd Off Road
554 27T Force I 22-24°Stock ROAR Legal
555 27T Force II 36° Stock NORRCA Legal
556 27T Mach I 24° Stock ROAR Legal
557 27T Mach II 38° Stock NORRCA Legal
ROAR Legal Tru-Stock 22-24°
05 Stock Motor 27T NORRCA Legal
Reedy Elite Stock 36° NORRCA Legal
Ultra-Sonic Series (Standard Comm)
560 12x2 “S”
561 12x5 “I”
562 11x5 “W”
564 13x4 “C”
565 13x2 “M”
566 13x5 “P”
567 14x2 “L”
568 14x4 “D”
569 15x4 “F”
570 16x4 “V”
571 10x4 “X”
572 10x3 “Y”
573 15x5 “B”
574 14x5 “A”
Nova Series
575 14x2
576 13x2
577 12x2
578 10x3
579 11x2
DS Spec
580 23T 18° DS Spec Motor (RC10DS Kit Motor)
DS Modifieds
586 17x3 “Z” DS Racing Motor
587 15x3 “B” DS Racing Motor
588 14x3 “A” DS Racing Motor
589 13x3 “E” DS Racing Motor
590 12x3 “H” DS Racing Motor
591 11x3 “T” DS Racing Motor
592 10x3 “Y” DS Racing Motor
3502 35T Stock 8 Minute Motor 1/2 2WD
Ultra Series
3522 20x4 Silver Star 1/12 2WD Scale Tracks
3523 19x3 Brown Dot 1/12 2WD High Speed Tracks
6502 27T Reedy Stock Ultra Style Case 1/10 1/12 2WD ROAR Legal
6521 21x2 Silver Dot 1/10 2WD Average/Tight Tracks or Monster Trucks
6522 17x2 Red Dot 1/10 2WD High Traction/Speed Tracks or Monster Trucks
6523 15x2 Pink Dot 1/10 4WD On/Off Road or 2WD Very High Speed Tracks
6524 19x2 Gold Dot 1/10 2WD Broad Power Band For Any Type Track
6525 14x2 Gold Star 1/10 4WD On/Off Road or 2WD Oval
6526 12x2 Blue Dot 1/10 2WD 6-Cell, 2WD/4WD Oval or Dragster
6527 13x2 Green Dot 1/10 4WD High Speed or All Oval
8100 16x4 Yellow Dot 1/10 2WD All-Around On Road
3509 AE Reedy E-S Sport 12 23T 1/12 On Road
6506 AE Reedy E-S Sport 4 17T 1/10 4WD Off Road
6507 AE Reedy E-S Sport 2 20T 1/10 2WD Off Road
6508 AE Reedy E-S Ultimate 2 19T 1/10 2WD Off Road
6509 AE Reedy E-S Ultimate 4 15T 1/10 4WD Off Road
6510 AE Reedy E-S Ultimate Oval 13T 1/10 2WD/4WD On/Off Road Oval
Revtech
4107 27x1 Pro Stock For 1/10 Or 1/12 Scale Road Racing - Oilite Bushings - Race Ready
4113 27x1 Esprit Stock ROAR And NORRCA Legal - Excellent For Offroad And Dirt Oval - Dyno Tested - Race Ready
4115 27x1 Maxima Stock
4118 27x1 Offroad Stock
4187 17T Turbo Sprint 2wd & 4wd 7 Cell Oval - 6 Cell Offroad (Evergreen Can With Gold Letters)
31109 9x1 Accelerator
31116 16x1 Express
31120 20x1 Contest Pro
31122 22x1 Enduro
31123 23x1 Enduro II
31214 14x2 Track Scorcher
31221 21x2 Turbo Enduro
31310 10x2 Maniac
31311 11x3 Turbo Sizzler
31313 13x3 Scorcher
31317 17x3 Turbo Sprint
31318 18x2 Sprint
31319 19x3 Contest Gold
31412 12x4 California Sizzler
31415 15x4 Turbo Express
33117 17x1 Carpet Sweeper
33215 15x2 Magic Carpet 1/12th
33216 16x2 Rug Ripper
33315 15x3 Magic Carpet
33413 13x4 Carpet Monster 1/12th
33414 14x4 Rug Rocket
41070 27T Pro Stock 1/10th 1/12th Road Racing (Bushings)
333314 14x3 Rug Ripper 1/12th
S&K Racing
Ironman
IM1010 Blue 24° ROAR '91 Stock (For Short Tracks)
IM1020 Red Hot 44° Stock
IM1030 Panther Stock
IM1040 Greyhound ROAR '91 Stock (For Long Tracks)
IM2--- Handwound Modified
IM5000 Dyno-Soar Slave Motor
Schumacher
Standards
G6001 35T 1/12 Yokomo Factory Advanced
G601J 27T 1/10 Ultrastock Factory Advanced
Tamiya
50189 23x1 RS-540SD Black Motor Sprint 16,300 RPM (Red Endbell)
50200 RS-540SD Black Motor Endurance 14,100 RPM (Blue Endbell)
50225 23x1 RX-540SD Technipower 20,300 RPM
50230 27x1 RX-540SD Technituned 17,200 RPM
50290 21x1 RX-540VZ Technigold 19,000 RPM
53001 19x1 Dynatech 01R 25,000 RPM
53044 13x2 Dynatech 02H 28,900 RPM
53068 23x1 RS-540 Sport Tuned 18,300 RPM
53122 14x2 Acto-Power Off Roader 2WD Motor 30,000 RPM
53153 15x2 Acto-Power Touring Special Motor 29,300 RPM
53154 17x2 Acto-Power Formula Motor 25,500 RPM
49567 12x2 Acto-Power TRF Tuned Motor 32,400 RPM
53251 22x1 Acto-Tuned M-Special Motor 19,000 RPM
53263 13x2 Dyna-Run Super Touring Motor 33,200 RPM
53272 17x1 Dyna-Run Racing Stock Motor 23,000 RPM
Team Altech
RH0918 Single - Red End Bell - Bearing - 30,000 RPM
RH25524 Double - Blue End Bell - Bearing - 21,000 RPM
RH26517 Double - Orange End Bell - Bearing - 32,000 RPM
RO821 Single - Blue End Bell - Bushing - 19,000 RPM
RO8522 Single - Yellow End Bell - Bushing - 19,000 RPM
Team Associated
6500 Stock 05 Motor Yokomo (RC10 Kit Motor) aka -Off Road Stock Motor-
6501 Stock 05 Competition Motor Yokomo - Tuned For Racing Use Only. Very Limited Life.
6502 Reedy Competition Stock Motor (Green/Chrome Label)
6505 Modified 05 Motor Club Racer - Off Road
6508 Modified Reedy/Yokomo Enforcer - Hot Oval
6509 Modified Reedy/Yokomo For 5-6 Minute Races
6510 Modified 05 Motor Reedy/Yokomo - Road
6510 Ultimate Oval Motor With Ball Bearings 2WD-4WD Oval Racing
6511 Modified 05 Motor Reedy/Yokomo - Oval
Team Atlas
AT7-110 23T Splash Gold Stock
AT7-121 14T DoriDori Stock
AT7-301 11x2 Excel-G
MH7-225 11x? Sinichi Edition
MH7-281 11x? Neo (SS)
Team Checkpoint
Platinum II Series .05 Racing Motors (Silver can, Black Label)
2018 Hotter Two Wheel Drive
2020 Two Wheel Drive Off Road
4012 Ultra Hot Oval -Requires Good Batteries
4013 Hotter Four Wheel Oval -Dominators 3 Minute
4014 Four Wheel Oval -Dominators Or SRP
4015 Hotter Four Wheel Drive -Recommended For Oval
4016 Two Wheel Drive -Recommended For Oval
4017 Four Wheel Or Hot Two Wheel Drive
Silver Series .05 Racing Motors (Black Can, Silver Label)
18 Turn Off Road Edition
16 Turn Oval Edition (4 Minutes)
.05 Racing Motors (Silver Can, Red Label)
Stage I ROAR Legal Dyno Stock
Stage II ORCCA Approved Off Road Stock
Stage III Hand Wound Modified
Stage IV Modular Brush System Off Road (Enduro Edition, Race Edition, Yokomo "Gold" Edition)
Stage V Modified On Road Edition
Team Cobra
Stock Motors
1125 44T Selectrics On Road Outlaw Stock
1126 44T Viper Off Road Outlaw Stock
1127 24T 24° Venom Slotted Roar Legal Stock
1128 44T 44° Venom Slotted Outlaw Stock
1129 36° Venom Short Stack Slotted Short Stack Outlaw Stock
12000 Copper Rocket Stock Copper Based Brush
12300 Hod Mod Special Modified Brush
12400 Silver Bullet Silver/Copper Based Brush
Team Losi Revolution Motors
6024 27x1 Super Insane 24° Stock ROAR '91 Slotted-Rotor 4.9 Wet Magnets
6026 27x1 Double Trouble 45° Outlaw Stock NORRCA Legal Double-Rotor Armature Wet Magnets
6027 27x1 Double Trouble 36° Stock Short-Stack Armature Wet Magnets (Hot-Pink Can)
6028 27x1 Big Ed ROAR '91 Stock (Green)
6040 21x2 Revolution II 2wd (Dry Magnet)
6046 19x2 Revolution IV 2wd (Dry Magnet)
6054 17x2 or 17x3 Oval (Dry Magnet)
6056 15x2 Insane (Dry Magnet)
6058 16x3 Brutus 4wd (Dry Magnet)
6058 14x2 Killer (Dry Magnet)
6060 27x1 Superstock
6070 11x3 Lightning Drag 4wd (Dry Magnet)
6101 18x3 Revolution Wet Mag II 2wd (Wet Magnet)
6102 16x4 Or 16x5 Revolution Wet Mag IV 4wd (Wet Magnet)
6103 17x2 Or 17x3 Jrʼs Choice (Wet Magnet)
6104 19x2 Or 18x4 MTM Monster Truck Motor (Wet Magnet)
6105 13x3 Daytona Oval (Wet Magnet)
6106 12x1 Motown Missile 2wd (Wet Magnet)
6107 11x4 On Road Special (Wet Magnet)
6108 15x4 Big Ed
6109 11x1 Super Insane
6110 14x2 Off Road Special
Team Pit Stop
Stock
3200 30° Super Stock
Machine Wound Modifieds
3300 18 Wind "Winner" Blue
3301 15 Wind "Winner" Pink
3400 18 Wind "T.Q." Blue
3401 15 Wind "T.Q." Pink
3402 14 Wind "T.Q." Green
Hand Wound "Super" Modifieds
3520 28x1 White Lightning
3521 21x1 Red Rocket
3522 19x2 Black Widower
3523 17x2 Silver Bullet
3524 24x1 Blue Blaster
3525 16x2 Yellow Jacket
3525-1 16x3 Brown Basher
3526 13x1 Gold Rush
3526-1 13x2 Orange Crusher
3526-2 13x5 Maroone Masher
3527 15x3 Pink Pussycat
3528 14x3 Green Monster Eater
3528-1 14x5 Track Terror
3529 11x2 Purple Pounder
3530 12x1 "Duke's Revenge" (R)
3531 11x1 "Radical Duke" (R)
Team Tanaplan
12x1
13x2
14x2
15x2
16x3
17x2
18x2
Team Yokomo
4800 13T Impulse Off Road 2wd & 4wd
Tekin
YM110-S Yokomo Based Off Road Stock ROAR & ORCCA Legal
Tower Hobbies
TOWCO100 27T 24° Legal Action Off Road ROAR Stock 28,000 RPM
TOWCO200 14x4 Speed Secret 4wd Off Road 40,000 RPM
Trinity
Street Fighter
548 13x2 41,000 RPM
549 15x2 34,000 RPM
550 17x2 27,500 RPM
551 19x2 22,500 RPM
552 21x2 20,500 RPM
Signal Racer 2
766 10x3 47,500 RPM
767 12x3 44,000 RPM
768 14x3 38,500 RPM
769 16x3 35,000 RPM
770 18x3 30,000 RPM
BOSS
781 10x2
782 11x2
783 12x2
784 13x3
785 14x3
786 15x4
787 16x4
1/12 Scale Motors (8 Minute Heats)
1004 20x2 4-Cell 32,000 RPM (Also Seen Listed As 16x2 39,200 RPM)
1005 21x3 4-Cell 33,000 RPM (Also Seen Listed As 17x3 38,000 RPM)
1006 22x4 4-Cell 34,000 RPM (Also Seen Listed As 18x4 36,000 RPM)
1007 23x2 6-Cell 29,000 RPM (Also Seen Listed As 20x2 29,000 RPM)
1008 24x3 6-Cell 30,000 RPM (Also Seen Listed As 21x3 28,000 RPM)
1009 24x4 6-Cell 31,000 RPM (Also Seen Listed As 22x4 27,000 RPM)
1010 19x1 4-Cell 31,000 RPM (Also Seen Listed As 15x1 40,000 RPM)
1011 21x1 6-Cell 30,000 RPM (Also Seen Listed As 19x1 32,000 RPM)
1012 10x2 The Big Daddy 49,500 RPM
Championship Modified Series
1700 9x2 Nuclear Meltdown
1777 10x3 Kevin, Kevin
1778 11x4 Helter Skelter
1779 12x3 Speed Metal
1780 13x1 Flash Point
1781 14x2 Buzz Saw
1782 15x4 Armageddon
1783 16x5 The Classic
1708 17x3 Joel Magic Johnson
Monster 1700 Power Series
1700 9x2 Nuclear Assault (Pulling or Drag) Aluminum Endbell 52,000 RPM
1701 10x2 Big Daddy II Aluminum Endbell 50,500 RPM
1702 11x2 Top Fuel II Aluminum Endbell 49,000 RPM
1703 12x2 Godzilla II (Oval) Aluminum Endbell 48,100 RPM
1704 13x2 King Kong (Drag) Aluminum Endbell 47,000 RPM
1705 14x2 Maximum Overdrive (Oval) Composite Endbell 46,000 RPM
1706 15x2 Behemoth (2WD Road Racing) Composite Endbell 44,000 RPM
1707 16x2 Gargantuan (All-Purpose) Composite Endbell 42,000 RPM
1708 17x3 Magic Speed Joel Johnson Signature (2WD Off Road) Composite Endbell 41,000 RPM
1709 18x2 Heavy Metal Thunder Composite Endbell 38,000 RPM
1710 19x2 Tyrannosaurus Rex Composite Endbell 36,000 RPM
1711 20x2 Killer Force Composite Endbell 34,000 RPM
1712 13x1 Torkzilla
1/10 Off Road Motors
2000 27x1 34° Monster Stock 23,000 RPM (Also Seen Listed As 24,200 RPM)
2002 16x1 Custom Sprint 41,000 RPM (Also Seen Listed As 15T)
2003 19x2 Enduro 34,000 RPM (Also Seen Listed As 35,000 RPM)
2004 18x2 Pure Gold 37,000 RPM (Aluminum Endbell)
2005 15x2 Oval 44,000 RPM (Also Seen Listed As 14T)
2006 20x2 Turbo Blast 32,000 RPM (Also Seen Listed as 19T and 30,000 RPM)
2007 14x2 Drag 45,000 RPM (Also Seen Listed As 13T)
2008 16x2 Whippoorwill Oval 40,000 RPM (Also Seen Listed As 39,500 RPM)
2009 15x1 Davis Wind 41,000 RPM
2010 19x2 Oval Blast 35,000 RPM (Also Seen Listed as 17T and 31,000 RPM)
2011 17x3 Joel Johnson Signature 39,000 RPM
2012 20x2 Clod Buster (Normal Rotation) 35,000 RPM (Also Seen Listed as 17T)
2013 20x2 Clod Buster (Reverse Rotation) 35,000 RPM (Also Seen Listed as 17T)
2014 11T Top Fuel 47,000 RPM
2015 12T Godzilla 46,200 RPM
2020 Reverse Monster Stock (Same Specs as 2000 Above But In Reverse Rotation.)
2030 16T Matched Madness (A Pair Of Modified Motors For Dual Motored Monster Trucks.) 34,000 RPM
2045 Monster Jam 45° Team Tuned Stock
1/10 On Road Motors
2100 25x2 26,000 RPM
2101 26x3 27,000 RPM
2102 27x4 28,000 RPM
2121 21T 12° Procar Spec Motor
Dirtinator 2 Hand Wound Epoxy Balanced Modified Motors
(Purple Cans With Kinwald Terminator Headshot.)
D2106 6x1 Drag/Speed Runs 55,200 RPM
D2107 7x1 Drag/Speed Runs 48,000 RPM
D2508 8x5 4wd High Bite Track 41,700 RPM
D2409 9x4 2wd High Bite Track 37,300 RPM
D2410 10x4 4wd Most Tracks 33,700 RPM
D2310 10x3 1/10 On Road 33,500 RPM
D2511 11x5 1/10 On Road/Oval 30,700 RPM
D2311 11x3 2wd Most Tracks 30,700 RPM
D2211 11x2 2wd Most Tracks 30,700 RPM
D2412 12x4 High Speed Tracks 28,300 RPM
D2312 12x3 4wd Loose Tracks 28,300 RPM
D2212 12x2 4wd Loose Tracks 28,300 RPM
D2313 13x3 1/10 Carpet Oval 26,300 RPM
D2213 13x2 2wd Lose Tracks 26,500 RPM
D2414 14x4 4033 All-Purpose Off Road 24,400 RPM
D2214 14x2 2wd No Traction Track 24,300 RPM
D2315 15x3 1/12 8 Minutes 22,700 RPM
D2416 16x4 Touring Cars 21,300 RPM
D2217 17x2 1/12 Touring 20,100 RPM
D3 Modifieds
D3106 6x1
D3107 7x1
D3112 12x1
D3113 13x1
D3208 8x2
D3209 9x2
D3210 10x2
D3211 11x2
D3212 12x2
D3213 13x2
D3214 14x2
D3310 10x3
D3311 11x3
D3312 12x3
D3313 13x3
D3315 15x3
D3317 17x3
D3414 14x4
D3416 16x4
D3510 10x5
D3611 11 Turn Hex (6 Wire)
D3612 12 Turn Hex (6 wire)
D3.5 Modifieds
D35210 10x2
D35211 11x2
D35212 12x2
D35213 13x2
D35216 16x2
D35311 11x3
D35313 13x3
D35314 14x3
D35315 15x3
D35412 12x4
D2 Modified Motors For The Team Losi XX-4
D4X212 12x2 Purple Can With Special Endbell Heatsinks "The Terror Continues"
D4X210 10x2 Purple Can With Special Endbell Heatsinks "The Terror Continues"
EX-Tech
"Experimental Team Use Only" Factory Racing EX-Modified
EX0107 7x1 Can Type: Full
EX0108 8x1 Can Type: Full
EX0114 14x1 Can Type: Full
EX0211 11x2 Can Type: Full
EX0212 12x2 Can Type: Full
EX0213 13x2 Can Type: Full
EX0215 15x2 Can Type: Full
EX0216 16x2 Can Type: Full
EX0310 10x2 Can Type: Full
EX0314 14x3 Can Type: 3-Hole
EX0411 11x4 Can Type: 3-Hole
EX0412 12x4 Can Type: Full
EX3209 9x2 Can Type: 3-Hole
EX3310 10x3 Can Type: 3-Hole
EX3312 12x3 Can Type: 3-Hole
EX3313 13x3 Can Type: 3-Hole
EX3316 16x3 Can Type: 3-Hole
EX3317 17x3 Can Type: 3-Hole
EX3318 18x3 Can Type: 3-Hole
EX3415 15x4 Can Type: 3-Hole
EX3417 17x4 Can Type: 3-Hole
EX-Tech (Kinwald)
(Black Cans With While Labels And Green Kinwald Text.)
TK1011 11x3
TK1012 12x2
TK1013 13x1
TK1014 14x2
TK1015 15x3
GT Touring Car Series
GT-1 Ball Bearing Modifieds
GT1-409 9x4 4wd Sticky Tight Tracks 39,900 RPM
GT1-410 10x4 4wd Sticky Tight Tracks 36,800 RPM
GT1-312 12x3 4wd Big Tracks 33,800 RPM
GT1-214 14x2 4wd Slippery Tracks/2wd 29,100 RPM
GT-2 15° Bushing Modifieds
GT2-411 11x4 4wd Sticky Tight Tracks 36,500 RPM
GT2-413 13x4 4wd Big Tracks 31,500 RPM
GT2-415 15x4 4wd/2wd With Sport Packs 28,000 RPM
GT2-317 17x3 4wd/2wd With Sport Packs 24,900 RPM
Impact Modified Motors
P1000 Impact Super Modified (Choice Of Dirtinator 2 Or 3 Winds)
Kinwald Pointblank Hand Wound Modified Motors
P638 10x41
P639 12x31
P640 13x31
P641 15x21
Machine Wound Modified Motors
RC2050 12x3 T-Tech 12 4wd On/Off Road 32,100 RPM
RC2051 14x3 T-Tech 14 4wd On/Off Road 29,300 RPM
RC2052 17x2 T-Tech 17 Touring/2wd Off Road 26,200 RPM
RC2053 19x2 T-Tech 19 Touring/F1 25,400 RPM
RC2054 21x2 T-Tech 21 Touring/F1 23,700 RPM
TK2018 13x2 BuggyWald 2wd Off Road 31,300 RPM
Monsters Of Touring
MOT213 13x2
MOT215 15x2
MOT217 17x2
MOT219 19x2
Pointblank Stock Motors
P350 Green 2 ROAR 91 Stock
P350R Green 2 ROAR 91 Stock
P360 27T 24° Vampyre ROAR Legal Stock
P370 27T 24° Vampyre ROAR Legal Stock (Reverse Rotation)
P380 NORRCA Pink 3 Laydown Brushes
P395 27T 24° FlashPoint ROAR Legal Stock
P396 27T 24° FlashPoint ROAR Legal Stock (Reverse Rotation)
Rare Earth Magnet Epoxy Balanced Drag Motors
P660 8T
P551 9T
P662 10T
P663 11T
ROAR/NORRCA Legal Stock Motors
RC2095 27x1 24° Midnight 24,300 RPM
RC2096 27x1 24° Midnight (Reverse Rotation) 24,300 RPM
RC2098 27x1 24° X-Star 25,000 RPM
RC2100 27x1 24° X-Star (Reverse Rotation) 25,000 RPM
RC2102 27x1 24° X-Star Pro (Silver Compound "E" Brushes Along With High Performance Tweaked Motor Springs. Zapped And Dyno Tuned.)
RC2104 27T Paradox (R/C’s First Rebuildable Stock Motor. - Midnight 2 Based)
RC2106 27T Paradox Pro (Dyno Tuned And Tweaked)
RC2295 27x1 24° Midnight 2 24,800 RPM
RC2296 27x1 24° Midnight 2 Pro 24,800 RPM (Trinity "E" Brushes Which Is A Siler Design Made Especially For Stock Motors. Dyno Tuned With Readout.)
RC2024 27T 24° Slot Machine ROAR '91 Stock Slotted Armature Comm Lock 25,000 RPM
RC2424 27T 24° Slot Machine 2 ROAR '91 Stock
Chameleon Spec Modifieds (Midnight 2 Based)
RC2108 19x1 24° Chameleon (Tagged Arm With Ball Bearings)
RC2110 19x1 24° Chameleon Pro (Hemi Wound Spec - Dyno Tuned And Tweaked 31,000 RPM)
P191 19T Speed Spec Modified (For A Class That Fits Between Stock And Modified.)
RC1000 36° Monster Stock Jr. Short-Stack Slotted Armature 4.9 Wet Magnets (Fluorescent-Pink Can)
RC2101 1/18 BRP Outlaw Oval Cars 28,300 RPM
RC2103 36° Monster Stock Jr 4 Pro - Midnight 2 Based (24° In The Endbell, And 12° In The Comm.)
RC2111 5D 27T 5° Stock Motor Built To The Submitted Spec For NORRCA And ROAR. Meets All The NORRCA/ROAR Technical Specifications For A Longer Lasting "Regulated" Speed Stock Motor.
Samarium Cobalt High Performance Racing Motors
RC1005 8x1 Drag Racing 59,500 RPM
RC1006 9x1 Drag Racing 53,050 RPM
RC1008 10x1 Drag Racing 47,300 RPM
RC1009 11x1 Drag/Boats 42,200 RPM
RC1010 12x2 Boats/Planes 37,600 RPM
RC1011 13x2 Boats/Planes 33,700 RPM
Speed Gems
9200 11x3 Topaz - 4wd/1/10th Oval 36,700 RPM
9201 16x3 Ruby - 2wd Off Road 25,600 RPM
9202 17x1 Sapphire - Monster Truck/Plane 24,100 RPM
9203 12x2 Diamond - 1/10th Oval 33,700 RPM
9204 14x2 Onyx - 2wd Off Road 29,100 RPM
9205 13x2 Garnet 32,100 RPM
9206 15x4 Jade - 2wd Trucks 27,061 RPM
9207 19x2 Quartz - Touring/F1 21,539 RPM
9208 10x3 Opal - Oval 39,700 RPM
9218 17x2 Amethyst 19,500 RPM
9219 13x3 Platinum 31,400 RPM
9220 9x2 Zircon 41,000 RPM
9250 9x2 Cryptonite 51,621 RPM
9251 11x2 Jet 45,370 RPM
9252 13x2 Kobal 38,671 RPM
9253 15x2 Titanite 33,784 RPM
9254 17x2 Amber 31,423 RPM
9255 10x2 Pyrite
9256 12x2 Nitronite
9257 14x2 Serpentine
9258 16x2 Chromium
9259 19x1 Arcornite
Speedworks
0001 20X1 Buggy Master 30,000 RPM
0002 16X2 427 4WD 36,000 RPM
0003 18X2 350 2WD 34,000 RPM
0004 24X1 Dirt Oval Stock 2WD Or 4WD 25,200 RPM
0005 25X1 Super Speedway Stock On Road 24,200 RPM
0007 15X2 Pole Position V2 39,300 RPM
0008 16X1 Monster Mash 36,200 RPM
0009 16X1 Monster Mash 2 (Reverse Rotation) 36,200 RPM
0012 20X3 Road Beast 30,000 RPM
0333 13X2 Oval Man Motor 45,100 RPM
0555 14X4 Tony Neisinger Signature Motor 40,000 RPM
0444 27X1 34° Joel Magic Johnson Signature 25,000 RPM
0446 13X3 Chris Doseck Worlds Championship Edition Motor 43,200 RPM
0450 27X1 45° Joel Johnson Stock Part 2 Split-Rotor Slotted Armature 4.9 Wet Magnets 28,000 RPM
Triad Series
0666 9X1 ROAR Legal 50,000 RPM
0667 10X1 ROAR Legal 49,000 RPM
0668 11X1 ROAR Legal 46,000 RPM
0669 12X1 ROAR Legal 43,000 RPM
0670 13X1 ROAR Legal 41,000 RPM
0777 15X1 Pro Stock Ground Zero 32,000 RPM
0914 27X1 24° The BOSS
2099 13X2 Psychotic Reaction 35,000 RPM
9224 27X1 24° Green Machine ROAR '91 NORRCA Legal Short-Stack 5.0 Wet Magnets Comm Lock 25,600 RPM
9310 10X2 Caliber Motors
9312 12X2
9314 14X2
9316 16X2
9424 27X1 24° Green Machine 2 14,390 RPM
9425 27X1 24° Green Machine 2 (Reverse) 14,390 RPM
Speedworks Marine
0445 24x1 9° .05 Stock 4.9 Wet Magnets Monster Marine 26,300 RPM
0447 18x2 .075 Modified 4.9 Wet Magnets Modified Marine 35,000 RPM (Black Can Without Label And Purple aluminum Endbell. Comes with 0676 Water Cooling Kit.)
0675 17x1 4.9 Wet Magnets Modified Triad Wave Ryder 37,000 RPM
Street Spec/NORRCA Pro Stock Motors
RC2097 27x1 30° Monster Stock Jr Three 27,900 RPM
SS2228 21x1 12° Street Spec Stock 20,800 RPM
Team Gold Dust Modified Motors
GD211 11x2 4wd/Buggies High Bite 33,300 RPM
GD311 11x3 4wd/Buggies High Bite 30,100 RPM
GD212 12x2 Buggies Tight Tracks 28,100 RPM
GD312 12x3 Buggies/Trucks Big Tracks 27,900 RPM
GD213 13x2 Trucks Tight Tracks 26,000 RPM
GD313 13x3 Buggies/Trucks Loose Tracks 25,800 RPM
GD214 14x2 Buggies/Trucks Loose Tracks 25,200 RPM
Twister
201 19x2 2WD Kris Moore Special
202 19x4 2WD Monster Truck
401 17x3 2WD/4WD Stadium Special
402 16x3 2WD/4WD Dirt Merchant
501 14x2 4WD SCE Special
701 14x3 Erik's Express
702 13x1 Cyclone Oval
704 14x1 Titan
705 12x2 Fast Eddie's Ride
1001 15x2 Hurricane
1002 17x2 Terminator
1003 21x2 Tornado
1004 15x3 Formula 10
1005 19x4 Formula 12
901 15x2 Expert On Road
902 17x2 4-cell On Road 1/12th
903 21x2 4-cell or 6-cell On Road
904 23x2 Asphalt On Road
905 25x2 SCR Special
Air Force
3700 23x2 Glider
3701 21x2 Direct Drive
3702 19x2 Gear Reduction
3710 20x2 Helicopter
3720 19x2 Economy Ball Bearing
3730 23x2 Bushing Direct Drive
Big Block Series
2001 12x3 Typhoon Over 50,000 RPM
2002 11x2 Annihilator Over 50,000 RPM
2003 13x3 Carolina Mountain Motor 48,000 RPM
2004 14x3 Flash 43,000 RPM / Black Can, Gold bell, Red Decal Chrome Lettering
2005 14X3 Clydesdale 42,000 RPM
2005R 14x3 Clydesdale 42,000 RPM (Reverse Rotation)
2006 13x3 Black Max 48,000 RPM / Bearing, Black Can, Gold bell, Gold Decal Red Lettering
2007 14x3 Street Racer 44,000 RPM
Cobalt Motors Blueprinted With Comm Rings
6000 14x1 Pulling/Boats
6001 13x3 Pulling/Drag/Boats
6002 12x3 Pulling/Drag/Boats
6003 11x3 Pulling/Drag/Boats
6004 10x3 Drag
6005 9x3 Drag
Doubles (Two Motors in One)
3900 Oval 12x3 Motor & 11x2 Arm
3901 Dirt Oval 13x3 Motor 12x2 Arm
3910 2wd Off Road 16X3 Motor 14X3 Arm
3920 Monster Truck 19x4 Motor 17x3 Arm
3930 Drag 11x1 Motor 12x1 Arm & Comm Ring
3940 Pulling 14x3 Motor 17x3 Arm & Comm Ring
Hydro Speed
3810 17x3 Dolphin Hi-Performance
3811 15x3 Shark Ultra-Performance
3820 19x2 Econo Hi-Performance, Bearing
3830 20x1 Econo Power, Bushing
Pocket Rockets
3000 27X1 Superpro Stock 27,000 RPM / Pink With Orange Yellow Rocket Decal
3001 17X1 4WD Offroad Bushing
3002 20X1 2WD Offroad Bushing
3003 15X2 4WD Offroad Bearing
3004 19X2 2WD Offroad Bearing / White Decal, Pink Lettering, Pink Rocket
Scorpion Series
606 24° ROAR 91 Scorpion Stock
806 27x3 24° Stock
806P 27x3 24° DynoMax Stock
2010 11x3 Modified
2011 12x3 Modified
2013 13x3 Modified Truck
3010 27x3 36° or 44° Stock
3010P 27x3 36° DynoMax Stock
3501 27x3 36° or 44° Signature Stock
3902 11x3/12x3 Doubles Modified
Signature Series
3500 27x1 Stock (Gold Dr. Von Quick Decal)
3600 11x2 Modified
3601 12x3 Modified
Stock Motors
802 27x1 24° Ultra Stock 2wd "Green" 27,000 RPM
802P 27x1 24° DynoMax "Green" 27,000 RPM
804 27x1 36° Ultra Stock 4wd "Pink" 27,000 RPM Gold Endbell Heatsinks
804P 27x1 36° DynoMax "Pink" 27,000 RPM Gold Endbell Heatsinks
Vantage Engineering
BM024 24° Banshee ROAR Legal Stock Split-Armature
BM036 27T 36° Banshee Short-Stack Split-Armature
Warlock
WLSD113 Speed Demon 11x3 Machine Wound With Bearings
WL270 Night-Stalker 24° Stock With Comp Laydown Brushes
WL270-2 Night-Stalker II 24° Stock With Comp Laydown Brushes Dyno Tuned With Printout
WL280 Silver Bullet 24° Stock Dyno Tuned With Printout & Silver Brushes
WL2000DT Rebuildable Stock motor Dyno Tuned Speed Balanced Diamond Cut Comm (Copper colored Epic can With Yellow Label)
Yokomo
YM-PS211 11T Pro Stock II
YM-PS221 21x2 Pro Stock II
Wing
Modified
YMW2 15x1 Wing 2
YMW4 16x1 Wing 4
Stock
YMW RF 23x1
YMW BG 15x1
Super Wing Pro System
MT - 17T
RF - 18T
Ultimate Vintage Brushed Motor Reference Guide
- 1301 Views
Last post by Lowgear
- 1382 Views
Last post by Dr. Robotnik
- 1497 Views
- 126 Views
Last post by ls1heli
- 462 Views
- 3167 Views
Last post by spru
- 529 Views
Last post by DPero
- 2355 Views
Last post by Bormac
