[Upd. at last! July 2016] FWD on FWD, YrfII-SP Civic-bodied
- Lonestar
- Has thanked: 626 times
- Been thanked: 166 times
One of the most innovative cars of the history of RC... canned a few months after its release as the racing rules went another direction from that gambled on by Masami and Masaaki. Makes it even more desirable if you ask me!
I've been at it for a while now, sourcing new parts, refurbishing the chassis, polishing the aluminium parts and so on so forth, but I never took pics before Here's where I am at now
The workbench is a mess
taking shape - frog? rabbit? grasshopper? Your call
I'll try to post more pics as I go.
Question - this is the first time in ages I do an old-school yoke diff with that crappy split washer and crappy bent screw... is there some kind of aftermarket parts that fit? I'm thinking a proper diff spring for instance. The range of adjustment is ridiculously tight on the current setup due to the quasi-absence of "spring" action... thanks!
Paul
Paul
- GJW
Re: Current Yokie Project :)
not easy to find are they paul! so your going to drive this i take it?? how long were they made for any idea? looks unreal cant wait for the finished product
those rear hub carriers look familiar
- Lonestar
Yes I will drive this one gently on indoor carpet tracks, once in a while (read - 4 laps / year at most )!marui hunter 73 wrote:not easy to find are they paul! so your going to drive this i take it?? how long were they made for any idea? looks unreal cant wait for the finished product
Not sure how long they were made for, I'd say less than a year before Yokomo fully focused on the YR4 and its evolutions as the TC category rules were finalized and mentionned 4wd only
It's pretty sought after these days... I also have a NiB that I bought last millenium for a ridiculous $90 from the infamous Jason... He had a pile of kits for sale back then, I should have picked up a few more It's funny how it's the oddball cars that pick up value as the years go...
Anyways - will keep you updated with the build. I feel pretty priviledged to have a chance to work on this one to be honest
Paul
- Has thanked: 10 times
- Been thanked: 447 times
you can use belleville washers, and a standard screw with locktite, OR...if the diff hub is threaded all the way through, add another 2mm screw in the threaded side to jam lock the adjusting screw.....does that make sense? you adjust the diff with the diff screw, then tighten the 'jam screw' on the other side.
a belleville washer from somewhere like mcmaster-carr would be the ticket...like this one....you can stack them to get the desired 'feel'
- Regular Member
- Lonestar
Thanks - yes, I was thinking belleville washers too, they are very hard to find in the small diameters though, usually they're sold in bulk for industrial purposes, whereas I'd just need a few. Shame that McMC doesn't ship overseas, there's so much stuff I'd buy from them I've already started looking for small-qty belleville washers...jwscab wrote:you can use belleville washers, and a standard screw with locktite, OR...if the diff hub is threaded all the way through, add another 2mm screw in the threaded side to jam lock the adjusting screw.....does that make sense? you adjust the diff with the diff screw, then tighten the 'jam screw' on the other side.
In the meantime, does anyone know of a 6mm outer-diameter diff spring? That's how small the diff outdrives are the yrf2...
thank you!
Paul
maybe this one? 7mm long though, probably too much for the assembly.
http://www3.towerhobbies.com/cgi-bin/wti0001p?&I=LXM491&P=7
how soon are you gonna be building this? I might be picking up some belleville washers for some yoke builds, but probably not till next week, I have an order I'm building with mcmaster....if you can wait, I can send you some.
- Lonestar
Hi therejwscab wrote:maybe this one? 7mm long though, probably too much for the assembly.
I think this one would be a tad long indeed and probably hit the dogbone... however that's the "stock" hpi/HB diff thrust spring from the old diff, and I might be able to get one locally indeed as it's a car that was hugely popular in our area! I feel stupid for not thinking about it myself, as I was running the HB cyclone up until last year
I'd love to repurchase a few belleville washers from you, really... that'd be very nice of you. No hurry at all, I can always fit them on later, really Let me try to get back to you with dimensions after this weekend Thanks a lot in advance!
Paul
yeah, that's no problem.....mcmcaster sells 'em in packs of 12, and I can send you 2 in an envelope for nothing....I'll let you know when I get 'em and you can pm me your address....I'm thinking 2 back to back will give you what you need. like this 'top thrust washer' '<' '>' 'thrust bolt
actually...you have a trx-1/3 right? check the diff thrust springs from that, they might fit! they are bellevilles.....
- Lonestar
I think the TRX are too big, but I'll check again. 6mm is tiny. The losi ones I have don't fit, and my xray T3's are small and already 8mm...jwscab wrote:yeah, that's no problem.....mcmcaster sells 'em in packs of 12, and I can send you 2 in an envelope for nothing....I'll let you know when I get 'em and you can pm me your address....I'm thinking 2 back to back will give you what you need. like this 'top thrust washer' '<' '>' 'thrust bolt
thanks for the offer the trick in picking belleville washers is to figure out which "tension" one you need... coming both from different materials, thickness, and deflection angles. Wilco.
thanks a lot,
Paul
yep, mcmaster offers 2 tensions, 7lb and 15lb. with the stupid lockwasher the only tension set on those diffs from the factory, I'm betting that using 2 7lb springs will do the trick. if not, they can be stacked.
once I get them, I'm going to rebuild a diff and see how it feels with just 2 7lbs. if that isn't enough, I'll double them up and try them. if that works, I'll pick up the 15lb ones and use those in the future.
- Lonestar
Here's where I am... I don't progress as quick as I'd like but I was racing twice the past couple of weekends so the YrII had to be depriorized Chassis is done, I already started dropping period electronics in it.... more pics to come in forthcoming days I hope
Joe was kind enough to send some belleville washers, thanks Joe! Haven't had time to install them yet. I'm sure they'll be great!
Paul
Paul
- Lonestar
Et voila with period electronics... still in need of a period body, suggestions welcome! I was told Masami was running an RX-7 shell on his. The diff feels much better with the belleville washers, but is still very finnicky to adjust, the bent M2 screw is really really not mechanically right.
The radio behind this is my old personal EX5 from back in the days... and it's so dirty I didn't date take any pics of it... yet!
Maiden run is planned early feb during the free practice of a carpet on-road race.
enjoy the pics till then
Paul
N
Paul
N
- Lonestar
A bit of thread digging, but for a good cause... I had parked this project for, litterally, years, as you can see. It had seated on the shelf un-bodied, until I realized, also years ago that I had a wonderful EH3 Civic body. It might be the other way around, I might have bought that almighty FWD body just for my almighty FWD yokomo. I believe this body was sold to me by Bernard Guidonnet - the name will ring a bell to French-speaking readers from Western Europe. Bernard had done a great job on the Apple scheme, with a few AutoRCM stickies to boot, too! Anyways, the body posts had been cut a tad too small by the previous owner (remember the Si is a hatchback...), so I had to park it for another while again. Then I sourced some (HPI) body posts. Then it was parked...
... then a few days ago I signed up for the Build Of The Month contest, and I thought this was the perfect motivator to wake up the sleeping beauty.
So, here we go - completed, at last! Another box ticked, on to the rest of the backlog
Remember we started with this (and you should have seen the underneath of the chassis...)
And we end up with this
(apologies for the crappy iphone4 pics, couldn't locate an SD card for my D60...)
Paul
Paul
- klavy69
- Moderator
- Has thanked: 561 times
- Been thanked: 265 times
Re: [Upd. at last! July 2016] FWD on FWD, YrfII-SP Civic-bod
I Do like this...I've been wanting a FWD and just haven't had the luck to land one yet. Like the backstory behind it too. Once again Paul it looks great.
- 2792 Views
Last post by bearrickster
- 161 Replies
- 12954 Views
- 47 Replies
- 9267 Views
Last post by johnekb
- 1455 Views
Last post by Germano
- 1542 Views
Last post by LTO_Dave
- 2497 Views
- 311 Replies
- 32097 Views
- 2448 Views
