Sorry if the question seems foolish, I was just wondering.
![Smile :)](./images/smilies/icon_smile.gif)
Weird...if you look at that image of all the Le Mans motor specs, several of them are smaller 540-sized cans that can handle even up to 9.6V, such as the 240S, 480S, 240SB and even the fastest one in the group, the 240WS. Heck, even the 600E, a 30T motor, can handle up to 9.6V. So why is the 480 Gold so relatively weak? Or is it even? I wonder if it's just a mistake or an oversight...Mad Racer wrote:The reason why they say the 360 series can handle 8.4v is beacuse it's a bigger motor. It is a 550 seize can. This produces more torque. They rev less too. So with 8.v the motor would do more RPM but not too much. A 540 will rev a lot more and most likly fail. ( Throw a wind off ) Remember back than the motors weren't as good as todays or should i say the last of brushed motors. The Epoxy if any will melt ( Holds windings tight) brushes would glaze up, Balancing of arm will shift due to the movement of the winds.
Cans weren't designed to extract heat and etc.
Users browsing this forum: Ahrefs [Bot] and 1 guest
