These are current part numbers for the gold pan buggy. im sure this has been posted many times but oh well. you can find at towerhobbies.com
6207- front suspension mount
6206- wide front a arm
6210- 30 deg caster blocks
6221- inline steering block
6220- front inline axle
6231- wide front shock strut (tower)
6330- body mount kit
6355- rear a arms
6366- 1.5 deg hub carrier
6321- nose tubes
6910- screw set
6334- battery cups
6181- wire and wing (rc10.com ONLY!!)
6471- shock shaft ends
1007- MIP CVD kit
hope this helps!
RC10 Parts
Re: RC10 Parts
Associated used to have the available parts listed on their website, but they changed it recently and I don't see it anymore. Just about the only parts you can't get anymore are the rear bulkhead, rear suspension mounts, rear shock tower, gearcase, motor plate, and chassis and nose plates. You can buy all the chassis internals and all the other suspension parts, and they will all keep even a 1984 car running (if not original).
- 4193 Views
Last post by mytimac
- 47 Replies
- 6901 Views
Last post by CON
- 1157 Views
Last post by DaveM
- 711 Views
Last post by tommy217xxx
- 1830 Views
- 763 Views
Last post by clayboy
- 25 Replies
- 2627 Views
Last post by 85Edinger
- 1003 Views
Last post by Group B
