Ok so I will have to front up and admit i know nothing about on road stuff let alone old AE on road stuff.
I recently picked up a job lot and I found a collection of old AE spares amongst it. I have no idea which car or cars they are for but if someone knows can you please help me out?
I dont intend to build up any on roaders but it would be nice to know which models these belong to.
Many thanks in advance- Jason Millward
Rare AE on road spares???
- a01butal
- Has thanked: 33 times
- Been thanked: 39 times
Re: Rare AE on road spares???
Jason, You have a combination of 1/8th, 1/10th and 1/12th scale parts. The parts that are series #5000 are for the RC500, and I see some 1/10th parts which would be #8000 series (RC10L, etc.). The rest look to be RC12e (#3000), 12i and not sure if there are 12L but those would be #4000 series. Some I'm not sure unless you gave me the specific part # as to which 12th scale version they go. The white kydex bumper is 12i or 12e weightsaver and the bigger bumper looks to be RC10L if it is 9" long.
This is all very interesting!
- Bormac
- Has thanked: 21 times
Thanks AL. There's heaps more that isnt even pictured. I will have to snap more pics tomorrow.
- Bormac
The list is as follows-
3211 - Steering blocks
3610 - Rear wheels
3652 - Front tyre donuts HARD/TRUED
3662 - Front tyres (no markings)
4112 - Steering blocks .050 offset
4113 - Springs .020
4114 - Spec. springs .018
4116 - Springs .024
4117 - Springs mil spec .022 wire
4118 - Springs mil spec .014 wire (black)
4120 - Cross brace for front end
4122 - Stub axle
4123 - King pin for I.S. front end
4124 - 'C' clips
4126 - Ball end tie rod set
4135 - Bumper
4180 - 2-56 screw set
4181 - Flat head aluminum screws
4185 - 8-32 nylon lock nut
4186 - 10-32 nylon lock nut
4323 - RC12L graphite chassis
4324 - Graphite upper brace
4325 - Graphite lower brace
4330 - Thin .062 T-Bar
4331 - Thick .074 T-Bar
4333 - Ball 4/40 screws and nuts
4337 - Aluminum tube
4340 - Damper plastic washers
4345 - LH Bulkhead
4348 - Axle bearing height adapter - no offset
4349 - Axle bearing height adapter #1 offset
4350 - Axle bearing height adapter #2 offset
4360 - Bearing mount for #4359
5101 - LH lower A arm
5102 - LH upper A arm
5108L - LH steering block with axle
5108R - RH steering block with axle
5212 - Flywheel - Picco, OPS & Rossi
5251L - New LH rear bulkhead
5251R - New RH rear bulkhead
5271 - Rubber bellows 'small'
5289 - Rear fibreglass shock mount
5370 - Diff 10/32 adj.screw
5501 - One way roller bearing
5522 - 16T drive sprocket
5525 - Smooth idler sprocket
5531 - Front bulkhead
5535 - LH outer wheel hub-w/one way
5536 - RH outer wheel hub-w/one way
5537 - Inner wheel hub
5546 - RH steering block
5547 - LH steering block
6390 - 8/32 nylon wing nuts
8126 - Front wheels -chrome-
8151 - Rear wheels -chrome-
8182 - Special 8/32 plain nuts
8179 - Suspension arm spacer
8187 - Front bumper -large-
8190 - T-Bar .075
8203 - Lower brace spacer
8231 - Shock spring .038
8232 - Shock spring .040
3610 - Rear wheels
4113 - Springs .020
4116 - Springs .024
4122 - Stub axle
4124 - 'C' clips
4135 - Bumper
4345 - LH Bulkhead
8190 - T-Bar .075
- 125 Views
Last post by gtv1
- 1188 Views
Last post by Farabomb
- 463 Views
- 1957 Views
Last post by mk-Zero
- 897 Views
Last post by amx73
- 1413 Views
Last post by abailey21
- 846 Views
Last post by CAT3K
- 1185 Views
Last post by kink
