Futaba question
Futaba question
Not sure if this is the correct thread...but here goes.
I Have an old FP-3PG Futaba Magnum radio. However I don't have the matching receiver crystal.
It's frequency is 75.710. I was told that I must get a matching RX crystal and couldn't swap them both out with some I already have.
- Halgar
- Has thanked: 145 times
- Been thanked: 189 times
Re: Futaba question
I would agree. As long as the radio/crystals/receivers are compatible, you should be able to swap without problem.
- Has thanked: 7 times
- Been thanked: 41 times
Re: Futaba question
I can't remember what prompted me to go reading through an instruction manual, but I *think* I remember reading that they say not to use a different frequency than what originally came with the radio because the radio and receiver are tuned to that specific frequency. Something about the different frequency crystals requiring fine tuning to get the signal just right or something like that.... Anyhow, I've always changed them out and never had a problem. Even mixing a newer Rx crystla with an older Tx crystal worked fine. Have at it
- LowClassCC
- Has thanked: 89 times
- Been thanked: 104 times
Re: Futaba question
here is the only frequency reference i found in the manual.
the manual is available for download on my site if you would like a copy.
3PG Manual.pdf
http://lowclasscc.net/downloads/f/futaba/
hope this helps clear things up a little.
3PG Manual.pdf
- RC10Eh
Re: Futaba question
I always understood that the receiver/transmitter were in fact tuned to that freq. And if you did swap out to stay as close as you can to the original. That being said, most problems occur by not putting the RX in Receiver and TX in Transmitter . And antennas should never be cut , they are a set length as well. One more thing , rechargeable nicads generate 1.2 volts , regular AA ( alkaline or newer ) generate 1.5 volts , a difference of 2.4 volts
Re: Futaba question
Thank You! Thank You! Thank You! All of you!
I popped in my crystal from my old magnum sport into the 'module'. 75.560 I believe it is. And Presto. Nice radio. Actually I found it with a B2(barely used, practically new) and a Mega2 charger at a thrift store for $20.
Works great.
Works great.
- GJW
Re: Futaba question
glad its all working for you. you must be very happy put some pics up when all installed mate.
Re: Futaba question
Well.....funny thing....it has the battery pack, but I had no way of charging it. So I got a #270-407 AA holder from Radio Shack and popped in my nicads, including the ones out of my camera.
I still need to figure out how to 'tune' my Novak racer esc to this radio. The steering adjustments are awesome.
- 780 Views
Last post by MarkyDents
- 925 Views
Last post by THEYTOOKMYTHUMB
- 1273 Views
Last post by ALRC10
- 1687 Views
- 730 Views
Last post by j.costick
- 872 Views
Last post by lebowski770
- 1048 Views
Last post by tamiyadan
- 1877 Views
Last post by knixdad
Users browsing this forum: No registered users and 39 guests
