10T runner build
- Has thanked: 189 times
- Been thanked: 594 times
10T runner build
Finally got a chance to start my 10T rebuild. Everything cleaned and started to reassemble. I added new RPM front bumper and nose plate. I have new tires and wheel, new team shocks and new RPM arms on the way. I think im going to add an RPM tranny and T3 slipper though as this will be a light runner. Is the T2 body the best fit besides the original?
Re: Yes another 10T build
Would I need to use RPM body mounts for the T2 body on an RC10T or will the stock mounts work?aeiou wrote:Loooking good so far. Yep, the T2 body drops right on.
Thanks.
SC10 -- FT B4.1
- aeiou
The stock mounts are the same for the 10T and T2, but on the T2 they are about 1/2" closer together in the rear. The RPM mounts have both mounting holes, so they are nice if you have them, and they're tough. Or, you can just move the stock mounts inward 1/4" on each side.sneako43 wrote:Would I need to use RPM body mounts for the T2 body on an RC10T or will the stock mounts work?aeiou wrote:Loooking good so far. Yep, the T2 body drops right on.
Thanks.
- Group B
Indeed, the RPM adjustable mounts are very tough, and do aid in getting the T2 body to fit a 10T.aeiou wrote:The stock mounts are the same for the 10T and T2, but on the T2 they are about 1/2" closer together in the rear. The RPM mounts have both mounting holes, so they are nice if you have them, and they're tough. Or, you can just move the stock mounts inward 1/4" on each side.sneako43 wrote:Would I need to use RPM body mounts for the T2 body on an RC10T or will the stock mounts work?aeiou wrote:Loooking good so far. Yep, the T2 body drops right on.
Thanks.
Personally I really like the T2 body on a 10T...it is the 10T body with just a little added modernness.
Re: 10T runner build
Probably answering my own question here:
So I need to drill out the suspension mounts 1/4" if I can't find the RPM mounts? I don't want to drill anything (especially parts that are no longer available) if I don't have to! The RPM website shows discontinued for the RC10T mounts...ebay is my next stop.
Anyone have an old set that is not in use?
SC10 -- FT B4.1
- Been thanked: 22 times
Being black and white like the worlds cars you have you ought to put a worlds chassis and have a worldsT lol Don
ps> i got yellow front wheels and tires for it lol
- 1286 Views
Last post by marlo
- 633 Views
Last post by RC Chick
- 1981 Views
Last post by discgolfer72
- 1115 Views
Last post by spider
- 690 Views
Last post by RC10th
- 1526 Views
Last post by Kayne
- 864 Views
Last post by Sixtysixdeuce
- 22 Replies
- 2051 Views
Last post by Prince Steve
